Awesome cant wait too see it all together every panel is bolt on and requires no modification :)
The only two things really are
If you run glanza wings like i have they dont have the side repeaters (this looks much better without them) all you gotta do is tuck the wiring into the inner wing and cable tie it down of you want, dont cut the wire off because it will just end up making your indicators flash like crazy when you put them on haha
And i also went for the glanza mirrors as they look much better than the n.a ones in my opinion if you fit these then you wil need the loom to make these work i havnt got that yet, so i litrally just tucked the wire behind my door card and you would never know it was there :)
