I'm going to remove my airbag wheel and fit a nice TRD one, obviously the airbag light will stay lit after this.
So is there any way to cheat the airbag system with resistors or the likes folks ?
Demon tweaks do a resistor that costs about £4.50 simply plug the two prongs into the existing plug and it'll work exactly the same as when you had an airbag in
That's the one I got, the airbag light pops up as usual and then goes off again just as it would with the airbag still in! And I've just got it tucked away in the cowl under the boss so you can't see it
  • 2 weeks later...
  • 4 weeks later...
