Hello people. In desperate need of a gearbox as mine has gave up on life today, and taken the clutch with it :(. Would preferably be after a LSD box, but beggars can't be choosers, so any healthy box is good!
Regards
Mike
I'm also on the lookout for a gearbox for my ep82 as mine shat itself the other night. Pm me pls
I'm also after a gearbox for my gt but I heard the glanza box had Different ratios which made the gt not drive so good?
same box drives the same its only 3rd and 4th gear that are a tat smaller geared not that much tho
So not much different to drive? I recall someone saying they put a glanza box in a gt and then had to replace it with a gt box because they weren't happy with the way it drove. Not sure where I read that when I was looking for a box before.
Glanza has shorter ratios in 3rd and 4th to help it as it weighed more than the gt. so it will accelerate quicker but has slightly less top mph in those gears
maybie they went oem lsd ( close ratio ) to a non lsd turbo box as they are totally diferent geared ( long gears )
