I'm forging my engine and once bedded in and I have some spare cash I'm going to be after a ecu but I'm stuck on what to go for what do people recommend??? I want to be able to run about 300-350hp, i'm on a drag wepr mani though so on external wastegate so no need any electronic boost controllers.
Any help would be much appreciated!!
You'd still benefit from having an electronic boost controller.
It all comes down to how much you want to spend..? Have you put aside £1k or 2/3k for an ecu and a map?
Speak to your tuner, let him know what you want it to do and he will have the best recommendation, no good having an ecu that your tuner cant tune.
excellent advice
I would talk to a few tuners if you can, get some pros and cons for different ecus and then make a choice.
Link G4+ units in their various versions are excellent ecus and reasonably priced.
