typh183 Posted February 7, 2016 Share Posted February 7, 2016 Putting a 5e in a car for a friend and have just realised were using the 4e, gearbox. I've got a 5e flywheel but the clutch is for a 4e. I know I need a 3e flywheel but could I get away with using a 5e clutch in the 4e gearbox?Any help much apreciated Quote Link to post Share on other sites
lukEp Posted February 7, 2016 Share Posted February 7, 2016 Are you talking fe or fte? If it's fe then both clutch will be the same if it's fte then the clutch won't fit the 5E flywheel. You have to use the 5E clutch till you get a 3e flywheel or have the fte flywheel machined so it fits the 5E crank. Quote Link to post Share on other sites
daniel_g Posted February 7, 2016 Share Posted February 7, 2016 5e engine, flywheel and clutch would work but they are only 200mm, where the 4efte clutch is 212mm. Quote Link to post Share on other sites
typh183 Posted February 7, 2016 Author Share Posted February 7, 2016 It's an FTE in talking about sorry I should have mentioned, I think we are just going to put a 5e clutch in it until we find a 3e flywheel Quote Link to post Share on other sites
Ksv15 Posted February 14, 2016 Share Posted February 14, 2016 Flywheel on caldina with 5e is 212mm Quote Link to post Share on other sites
