it seems the general consensus from years ago is that they do nothing...basically you can shift the power band slightly from the left or right...but hp gains are non-existent
in a nut shell, our cams are linked and that's part of the "problem"
apparently they look good on the engines though...lol.....but again becareful, as some people reported that the timing was sometimes off, so you would need to double check everything
Edited by gorganl2000
Ah I know I've seen all post related to cams an Cam gears
Just curious if there a simple fit or awkward setting right looking for some1 with previous experience thanks though appreciate the input
If you were to use one use a dti to find tdc on no1 with the stock setup, should be close to the head markings id assume?
Either way, mark it down and replicate it with the adjustable one to be sure its the same
