decdd19 Posted February 17, 2016 Share Posted February 17, 2016 As above who has adjustable cam gears on standard cams? Just wondering if there simple set up thanks Quote Link to post Share on other sites
Whitenoize Posted February 17, 2016 Share Posted February 17, 2016 (edited) No need for them at all mate on our engines Edited February 17, 2016 by Whitenoize Quote Link to post Share on other sites
decdd19 Posted February 17, 2016 Author Share Posted February 17, 2016 Just after the blue of it mate looks smart behind clear Cam cover Quote Link to post Share on other sites
gorganl2000 Posted February 17, 2016 Share Posted February 17, 2016 (edited) it seems the general consensus from years ago is that they do nothing...basically you can shift the power band slightly from the left or right...but hp gains are non-existent in a nut shell, our cams are linked and that's part of the "problem" apparently they look good on the engines though...lol.....but again becareful, as some people reported that the timing was sometimes off, so you would need to double check everything Edited February 17, 2016 by gorganl2000 Quote Link to post Share on other sites
decdd19 Posted February 17, 2016 Author Share Posted February 17, 2016 Ah I know I've seen all post related to cams an Cam gears Just curious if there a simple fit or awkward setting right looking for some1 with previous experience thanks though appreciate the input Quote Link to post Share on other sites
5e colin Posted February 17, 2016 Share Posted February 17, 2016 get the stock 1 powder coated so no isseus with them collapsing etc etc Quote Link to post Share on other sites
decdd19 Posted February 17, 2016 Author Share Posted February 17, 2016 Good idea actually might do that Quote Link to post Share on other sites
morgey Posted February 17, 2016 Share Posted February 17, 2016 If you were to use one use a dti to find tdc on no1 with the stock setup, should be close to the head markings id assume?Either way, mark it down and replicate it with the adjustable one to be sure its the same Quote Link to post Share on other sites
christyep91 Posted February 20, 2016 Share Posted February 20, 2016 I wonder what would the stock one look like polished.it might look good Quote Link to post Share on other sites
Calum122 Posted February 20, 2016 Share Posted February 20, 2016 Ummm yeah, why didn't I think of that Colin, good shout. So obvious I just forgot! Quote Link to post Share on other sites
