5e colin Posted February 27, 2016 Posted February 27, 2016 hey guys want to make an rpm activated switch any of ye have a link to some diy kits Quote
Calum122 Posted February 27, 2016 Posted February 27, 2016 Could use a Microboard Arduino, or Raspberry pi, connected to a software activated relay when tachometer induced wire reaches said RPM. By using flux you can detect RPM's through the Spark plug leads. The raspberry Pi can be used to activate the relay, the relay acts as your switch Quote
lukEp Posted February 27, 2016 Posted February 27, 2016 Wow over kill on the RPi. https://www.google.co.uk/search?ie=UTF-8&client=ms-android-samsung&source=android-browser&q=shift+light&gfe_rd=cr&ei=UPrRVvyhNcavwQOK-5HoAQ#q=diy+shift+light Quote
5e colin Posted February 27, 2016 Author Posted February 27, 2016 (edited) Could use a Microboard Arduino, or Raspberry pi, connected to a software activated relay when tachometer induced wire reaches said RPM. By using flux you can detect RPM's through the Spark plug leads. The raspberry Pi can be used to activate the relay, the relay acts as your switch ????????? what did you just say ?? im an old school guy !!! ha ha link to a kit please so i can butcher /solder it together and see if it works ha ha luke i googled that indeed cheers Edited February 27, 2016 by 5e colin Quote
lukEp Posted February 27, 2016 Posted February 27, 2016 Just replace the light with a relay simples! Quote
5e colin Posted February 27, 2016 Author Posted February 27, 2016 Just replace the light with a relay simples! for you my friend for you ha ha Quote
Calum122 Posted February 27, 2016 Posted February 27, 2016 Hence why I said Arduino. But for the price of an Arduino you could get a Pi.I will admit Luke has the better idea lol. Quote
lukEp Posted February 27, 2016 Posted February 27, 2016 http://pages.ebay.com/link/?nav=item.view&id=331354062251&alt=web Pull it apart. Remove the LED/bulb replace with a relay. You can then set the relay to activate at any rpm between 1000-11000rpm all for less than £10 Quote
lukEp Posted February 27, 2016 Posted February 27, 2016 Actually you could do with finding out if the LED flashes or not at the desired RPM before you buy. You need it to not flash. Quote
5e colin Posted February 27, 2016 Author Posted February 27, 2016 why flash ?? that wil be power no power on of on of ??? i need a constant + feed from 6000rpm+- to keep my vsvNC open and my micro switch closes my vsvNO wen i wot Quote
Calum122 Posted February 27, 2016 Posted February 27, 2016 That's a much better idea than mine lol! Quote
5e colin Posted February 27, 2016 Author Posted February 27, 2016 nice 1 amigo on the shiftlight i can use this relay ?? i think and wire the 2 bulb wires to the silver terminals of this relay am i right ?? ( i think so ) >https://www.youtube.com/watch?v=Tw9QkkT2ptU Quote
pockrockgtti Posted February 27, 2016 Posted February 27, 2016 Boom http://www.jaycar.co.uk/Automotive-%26-Mobile-Security/Car-Electronic-Access-%26-Accessories/Car-Access-Accessories/RELAY-SWITCH-FREQUENCY-MODULE-PULSE-OUT/p/AA0377 Quote
lukEp Posted February 27, 2016 Posted February 27, 2016 Boom http://www.jaycar.co.uk/Automotive-%26-Mobile-Security/Car-Electronic-Access-%26-Accessories/Car-Access-Accessories/RELAY-SWITCH-FREQUENCY-MODULE-PULSE-OUT/p/AA0377Where is the like button?!?!? Quote
5e colin Posted February 28, 2016 Author Posted February 28, 2016 Boom http://www.jaycar.co.uk/Automotive-%26-Mobile-Security/Car-Electronic-Access-%26-Accessories/Car-Access-Accessories/RELAY-SWITCH-FREQUENCY-MODULE-PULSE-OUT/p/AA0377 BOOOM thats a bargain cheers man going to buy 1 tomorows see how i get on mine and lukes like button >>>>>>> Quote
