So i found another oil leak. When i park up the car leaves a drop of oil right underneath the timing belt cover and so when i look underneath the bottom of the cover is covered in oil. I changed the cranshaft seal 4 years ago so could it be that or something else?
Could be rocker cover. Spent ages driving to fix oil leaks on my 4e. Fighting a Losing battle, 4efte is about as useful as a sieve for keeping oil
Yeah clean off all the leaking oil completely then run the engine up and just look to see where it is leaking from. Good luck.
  • 2 weeks later...
So i looked round the rocker cover and its bone dry. the leak seems to be coming from underneath the timing belt cover. I cleaned all the old oil and drove it for 30 mins and looked under and the bottom of the cover is wet. Ive changed the crank seal about 4 years ago i say. What else is under there that can leak now that it leaves a spot everywhere i park?
Back of the rocker cover..its hard to see as mines weeping a little there at the moment..Oil seeps between the too covers and gathers at the bottom.
Have the same oil leak used a very cheap rocker seal believe it's that as it's all over cam over and under rocker getting genuine toyota one Fri.
