Ngk iridium, pre-gapped?, edit: pop/bang on boost, help?
  • Replies 102
  • Created
  • Last Reply
Top Posters In This Topic
A wider gap gives a stronger spark, only if its not blowing out.
I would start at 1.1mm, if you get a missfire under load, ie uphill 4th gear. Then gap it down to 1.00mm and so on.
Hence people running bigger tubbys are wanting a coil pack setup which provides a stronger more stable spark especially at the upper rev limit
