Simon Posted November 9, 2012 Posted November 9, 2012 Since i sold my ignition barrel light a few people have asked me for a wiring diagram.There are 3 wires to these lights:black - earth earth to the bodyRed/silver with a white stripeRed/silverThese are wired in on a Glanza behind the pannel below the steering wheel.If you remove the air ducting you will find acess easier. On the right clipped to the body you will find a plug like this:The red/silver wire goes to this red wire in the above picture(please note the location not the wire colour as it looks like my car has a small extension harness between the plugs guess this is how toyota fitted the lights originally)Above is where the red/silver white stripe wire is connected.Down behind the kick pannel there is a factory earth point that you can use for the black earth wire.Please remember when buying these you need get the small control box with it this is what turns the light on and off to stop it draining your battery and staying on all the time when the door is closed.Hope this helps Quote
Socks Posted November 9, 2012 Posted November 9, 2012 I did a wiki guide for this! However we lost it on the transfer!Ill push this to wiki today!Footwell Lights & Ignition Barrel Light... RUn off the same 7 second controller box! Quote
Matts Posted February 16, 2013 Posted February 16, 2013 Since i sold my ignition barrel light a few people have asked me for a wiring diagram.There are 3 wires to these lights:black - earth earth to the bodyRed/silver with a white stripeRed/silverThese are wired in on a Glanza behind the pannel below the steering wheel.If you remove the air ducting you will find acess easier. On the right clipped to the body you will find a plug like this:The red/silver wire goes to this red wire in the above picture(please note the location not the wire colour as it looks like my car has a small extension harness between the plugs guess this is how toyota fitted the lights originally)Please remember when buying these you need get the small control box with it this is what turns the light on and off to stop it draining your battery and staying on all the time when the door is closed.Hope this helpsIs this the diagram for an n/a buddy really want to find a diagram to wire the light into a uk n/a Quote
DaddyDutch Posted April 15, 2013 Posted April 15, 2013 What does the control box look like on these, is it the black box? Last time I tried to wire mine in, I fried the circuit board behind the clocks... Al. Quote
Jap91 Posted May 30, 2013 Posted May 30, 2013 I cant find that first plug for the life of me.. Got my glow light this morning Quote
JDMfreak Posted July 14, 2015 Posted July 14, 2015 bump picked a set of these up today and for the life of me I duuno where these plug into Quote
Flynn Posted July 14, 2015 Posted July 14, 2015 Random, I literally looked this thread up today to try and instal mine! Still none the wiser after trawling through all the old threads.......surely someone must be able to do a "how 2" with pictures would be helpful? I've got everything to just plug apparently? 2 white plugs and an earthLooked behind the kick panel/side trim by drivers door but can't figure out what I'm doing Quote
JDMfreak Posted July 14, 2015 Posted July 14, 2015 Random, I literally looked this thread up today to try and instal mine! Still none the wiser after trawling through all the old threads.......surely someone must be able to do a "how 2" with pictures would be helpful? I've got everything to just plug apparently? 2 white plugs and an earthLooked behind the kick panel/side trim by drivers door but can't figure out what I'm doing im the same mine only have 4 wires in each plug though I for some reason think ive the wrong connector blocks Quote
Flynn Posted July 14, 2015 Posted July 14, 2015 I'll take a picture of what I've got tomoz mate Quote
chriswep91 Posted January 22, 2016 Posted January 22, 2016 Did anyone manage to get pics for this? Quote
Flynn Posted January 22, 2016 Posted January 22, 2016 I got mine sorted, pretty sure there were pics in another thread? I'll see if I've got pictures on my phone somewhere. Quote
Ryan5793 Posted January 22, 2016 Posted January 22, 2016 Would be great if you could please mate might do mine then that I've had about 2 years now :/ Quote
Flynn Posted January 22, 2016 Posted January 22, 2016 Ok if I remember correctly. Providing you have these plugs on the footwell/ignition light You just unplug the smaller of the two plugs behind the drivers kick panel and plug the male bit on the lighting loom into the female on the car and the male that came out goes into the female on the loom......think that makes sense? And then earth it on the chassis Quote
Ryan5793 Posted January 23, 2016 Posted January 23, 2016 i get ya, cheers mate will have to give it ago tho im sure mine dont have the plug Quote
Flynn Posted January 23, 2016 Posted January 23, 2016 Yea that's the problem I had with the first ignition barrel light I bought, it had just been chopped out. Second one I got lucky with and it was all there (true plug and play) but there is definitely a difference between the plugs on the GT and Glanza though......think you may even have to connect the GT one in the passengers footwell? Quote
