glanzatd04l220
    180
About glanzatd04l220
  • Birthday 01/14/1988
    kilrea derry
1783 profile views
glanzatd04l220's Achievements
  1. when i made my mani i used 1 1/4" 45 short radio bends sch 40 3.6mm thick, if i mind right i needed 12 bends to make a ram horn mani and i bought them of a company called BSS. if i mind right i sent u a bend for your external wast gate, thats what i made my mani out of. kevin
  2. just looking to know if the cusco rear coilovers can be rebuilt, the two i have are both leaking. kevin
  3. as above looking a tial or turbosmart wastgate with flanges if possible. let me know what you have. kevin
  4. im using a standard corolla clutch in my car ( RYMEC VA6084) running 1 bar 215bhp for over 5500 kph and is standing the power perfect, also was only £80 for the kit. kevin
  5. i made my own ramhorn mani but when i made the decat i only made it 2" so looking any 2 1/2" decat and i'll modify it to suit my set up. kevin
  6. i also bought a cheap gauge and it was reading 0.2 bar more, so bought a racetech and its spot on. buy cheap buy twice. kevin
  7. wanted td04l down pipe 2 1/2 inch no toyo sport rubbish. prefer mild steel but will consider stainless steel. kevin
  8. The injectors were flow tested, if i fitted the 370cc injectors would the ecu not just flow the same amout of fuel through them as the 295cc injectors Kevin
  9. Running td04l with all supporting modes ecu e manage blue, im using standard 295cc injectors but was looking to know if i put a set of these 370cc injectors in will the car run fine or will she need remapped? Kevin
  10. ive a set off 370cc injectors direct fit if your interested. kevin
  11. i'll replace the ht leads, distributor cap and rotor arm and see if it helps. kevin
  12. changed the plugs to ngk bkr7eix and still interferes with the tv. kevin
  13. going to replace the spark plugs and see what happens, what plugs should i put in? running tdo4l at 1 bar 215 bhp. kevin
  14. it interferes with the tv's like a mini moto, might try different plugs and see if it helps. so no one else's car interferes with tv's? kevin
  15. i know lads its a joke, i even heard a women in the shop saying she 's going to report me to the police little did she know i was standing behind her. would having the wrong plugs in be interfering with the tv's, and im not running cb or scanner.
