Androo26
    66
    Australia
1621 profile views
Androo26's Achievements
  1. Ive had on my starlet for some time the Big brake kit from MRP in NewZealand. Great piece of kit bolting straight up with no mods required. I do track days as often as i can and have just put in a new set of Ferodo DS2500 pads to try out. This part number suits the 275mm rotor and Dynapro Caliper. Ferodo DS2500 part number is. FPR3149H. Check with your supplier for fitment.
  2. Hi guys .... its been a while but i might just share some recent turbo action regarding the 4cm vs 6cm thing. So as you may have already read I had a 4cm TF035 exhaust housing machined out to fit a bone stock TD04L. On 19 psi this setup netted me a healthy 160kw at the wheels. After some time i felt that maybe there was some decent ( not in a good way ) back pressure happening due to the small rear housing. I built myself a device to measure it and see. After this I put the exhaust housing back to the stock TD04 6cm one. This netted an 18% reduction in manifold back pressure 😀 Excellent ! I can go one better , So i got myself a Kinugawa TD04HL-15T With the Billet compressor wheel ect. This turbo is a good size bigger on the turbine wheel side than a TD04L 52mm outer 44mm inner for the HL and 47mm outer and 41.3mm on the inner for the L. I also opted for the 9 blade turbine wheel . (stock is 12 blades. ) This netted a further reduction in back pressure of 8.5% . Giving me a exhaust to intake ratio of 1.22:1 at 19psi. Pretty happy with the outcome. It was only 200 rpm later to max psi going from the TD04L to the TD04HL-15T
  3. I got mine from a 99 Forester. From my research this may have been the only vehicle to come with the 4cm TF035. The others had 6cm TF035
  4. I’ll just add my dyno graph here too . 4cm TDO4 19psi
  5. As promised ive got out and done some testing on the new setup with great results. Swapping over to the stock TD04 6cm rear housing has seen a big drop in turbine back pressure over the 4cm unit I had been using. 18.75% reduction in back pressure. From 32psi down to 26psi Making the ratio now 1.33:1 as before it was 1.68:1 (Intake manifold saw 19-19.5psi) The difference in Boost/ RPM is as follows 4cm housing 5psi at 2700 10psi at 3150 15psi at 3700 6cm.housing 5psi at 2850. 10psi at 3350. 15psi at 3800 As you can see it takes a little more RPM to reach the same boost levels. ( all of 200 rpm for 10 psi at most). So roughly 100-200 rpm later across the board. How does it drive ?? It is noticeable to drive between the 2. The 4 cm is a very fun setup and hits harder invoking wheel spin with ease The 6cm is more linear and smooth. To be honest i like it better and gets better traction, less shock loading on everything also. Whats next you say ?? Well Kinugawa make a TD04 that has a 9 blade turbine wheel as opposed to the stock ones having 12. Less back pressure again I would have thought. Option this with a billet compressor and or step it up to a 15T/19T. Im really not after any more power as it was tuned with the small housing and still made 160kw to the wheels but less back pressure will make for an overall more efficient setup. Im going to try get this on a dyno again if i can , see what the numbers are.
  6. Just a couple pics from last weekends turbine housing swap. With any luck I’ll be able to get som data logs done today . I also added a flex joint to the external gate recirculation pipe.
  7. How good is that ! I never would have known. Thank you sir.
  8. Yeah I think it is unfortunately, I had my entire build on there. Oh well I guess i can just share my stuff here instead.
  9. Its been a long time , but ive got some further information to share. Since the last post Ive built a forged 1.3L 4E and still have the 4cm Turbine TD04L on board. This has made a best of 160.0 Kw at the wheels on 19 psi. Super fun to drive and traction is a problem even with a Quaife LSD. Long story short is im getting a bit more serious about lap times and also improving the efficiency of the turbo setup. So i decided to measure the turbine back pressure vs intake manifold pressure. Turns out its a bit high for my liking. 1.68:1 . Id much rather it around the 1.5:1 or less. Im going to get the original 6cm housing Ceramic coated and then swap it over essentially making it a stock TD04L again. I will re take the turbine back pressure measurement and get back to you guys with the findings. Still very much enjoying the Starlet life here in Australia.
  10. Well Ive got something a little different..... A 4cm TFO35 rear housing machined to fit a TD04. Good spool up with good flow. I also use a 35mm Turbosmart External gate. A fantastic compromise.
  11. I would agree with what the other guys have said too. Read this article and you can make an educated decision for your self by testing it. Not just because others said too. ( hope this helps ) http://www.wallaceracing.com/plug-reading-lm.html
  12. I dont have a BOV and mine make the best flutter ever !!
  13. I had this on the dyno last week .. Whilst im not going to talk power figures I can tell you that Peak HP was at 5570rpm and peak torque at 4417rpm At 5600 boost dropped 1 psi so its possible that peak HP may have stayed flat peak till the end. RPM Range 4E 4cm TF/TD 4E 4cm TD04 5E 4cm TD04 2-3k 16 15 13 3-4k 11 11 10 4-5k 12 10 10 5-6k 15 15 12 Total logs 54 51 45 Here is the log count and as you can see its still pulling well in the upper rpm. 5E for the win thats for sure.
  14. Rightio then lads ive done some data logs on spool up with this 4CM TD04 hybrid im running. For those that dont know my setup its a rebuilt N/A 5EFE completely stock 9.5:1 comp. Turbosmart 38mm External waste gate. 4EFE Intake manifold. It runs a GFB Atom bleed valve (very basic) so this is about as slow/ linear to build boost as your going to get with no waste gate trickery at all. The run was performed in 3rd gear, foot flat to the floor from 2000 rpm till redline 6K 1 psi 2000 rpm 3 psi 2120 rpm 4 psi 2250 rpm 5 psi 2380 rpm 6 psi 2410 rpm 8 psi 2560 rpm I might just add that using a bleed valve the gate at this point is almost all the way open as it going to get. So if it were using an EBC you could still have the gate completely closed if you wanted making use of all the exhaust gas 9 psi 2620 rpm making it spool faster again. But Ive chosen the bleed valve because its more gradual and better for traction. (still awesome response on the street) 10 psi 2950 rpm
  15. Rightio then lads ive done some data logs on spool up with this 4CM TD04 hybrid im running. For those that dont know my setup its a rebuilt N/A 5EFE completely stock 9.5:1 comp. Turbosmart 38mm External waste gate. 4EFE Intake manifold. It runs a GFB Atom bleed valve (very basic) so this is about as slow/ linear to build boost as your going to get with no waste gate trickery at all. The run was performed in 3rd gear, foot flat to the floor from 2000 rpm till redline 6K 1 psi 2000 rpm 3 psi 2120 rpm 4 psi 2250 rpm 5 psi 2380 rpm 6 psi 2410 rpm 8 psi 2560 rpm I might just add that using a bleed valve the gate at this point is almost all the way open as it going to get. So if it were using an EBC you could still have the gate completely closed if you wanted making use of all the exhaust gas 9 psi 2620 rpm making it spool faster again. But Ive chosen the bleed valve because its more gradual and better for traction. (still awesome response on the street) 10 psi 2950 rpm
