owenroche2@hotmail.co.uk
Club Member
    7
    suffolk
3053 profile views
owenroche2@hotmail.co.uk's Achievements
  1. I’ve stripped all the abs parts out of the car and removed the looms ready to paint the bay the plan is to removal all un needed wires from the loom. question is I remember the cable coming from the rear of the car (for the tail lights?) plugging into this ecu do I need to keep this or is there another place for this loom to plug in?
  2. Hi does anyone know if there’s rods that are a direct replacement for pec ones? I’ve got wossner pistons and after waiting 4 months for the rods I’m now being told there’s no eta!
  3. wanted! n/s rear caliper 07974990833
  4. Has anyone else had issues with the fitment of this exhaust most of my problems seam to stem from the back box. banging on the centre of the car on the bend and the tip sitting 20mm inwards towards the front of the car! Mikes not exactly being helpful dispite me going out my way to put the car up on a ramp to show him fitment and even going as far as offering to measure each section all I’ve really had so far is “These are all made in jigs so we don't get discrepancies you see.” ive even said I’ll take it to a local exhaust place to have it sorted under warranty but again it’s just swings and roundabouts!
  5. Can anyone tell me the gap between the sensor pick ups on the rotor gear. Stupidly I had to extract and rounded off screw and managed to push the rotor gear into the pickups causing a code 12/13 I’ve move it out and now it runs again but if I plant it the eml flashes on then off
  6. Thanks for the reply today I went though everything checked distributor plug wire to ecu all fine then I checked the power going to the coil 12v switched on one pin then 18v on the other while cranking it doesn’t have any spark so it must of been a very weak one I see last night I’ve ordered a new coil I checked and cleaned grounds on the coil and bracket still a bit stumped why’s it’s saying code 12 for a coil not making spark
  7. ive got a problem with my glanza i changed the ignition parts today with a kit from tuning developments after i put everything back together i went to start and it turned over about 3 times then just gave up turned key off then on again and it fired up but with the eml on as i came to a stop round the corner from my house it went off then as soon as i pulled off it came back on again i checked the codes and got code 12 (RPM Signal No G or NE signal present for 2 seconds during cranking Open G circuit Open, short in G or NE circuit) so i checked all the plugs again and still had the same problem but then i went to go off again and it refused to start after a couple of tries i came back to life and felt normal rpm gauge still works i put all the old igniton stuff back on and its still go the same problem its got spark and smells like fuel when it turns over but it take a few goes and a bit of throttle and it starts and run fine apart from a low ish idle ive tried putting a jump lead from ground to the engine ive had the ecu out and checked grounds wires seem fine ive cleaned the distributor plug with contact cleaner ive checked the pump primes, it worked fine other then a misfire before i had everything out its got a brand new battery on and ive tried others to check its not the problem if anyone can help itll be hugely appreciated.
