ryan lang
    8959
  1. i know dw matey haha
  2. aha i literally lol'd to that one haha
  3. it will have been the knock sensor mate. the knock sensor is one of the leading factors in adjustment of fuel. also taggy, you still have to show me this soon! haha. still no news on a car for me yet though but when i do get one we'll go out for a drive so you can show me the best roads and take some pictures
  4. under the fuel pressure regulator theres a small pipe that goes into the number 1 runner on the inlet manifold, you havent left that off or knocked it off on accident. its in the area of the alternator so may have knocked it off
  5. Found it...
  6. cant see shit! pics are tiny and all need rotating
  7. no dude, its been covered a few times pistons are different, valve springs are different, thermo housing is different, sump is different, sump pickup is different, rods differ between some models, tb is different, inlet manifold is different, injectors are different, it doesnt have a knock sensor, the attatchment for the oil filter cant be bolted onto the block, theres extra pipes on the coolant temp sensor housing for lines to the turbo distributor cap is different external coil ignition system fuel pressure regulator is different theres more to the list but i cant think of them off the top of my head at the moment
  8. sounds like a boost leak from somewhere
  9. cambelt is on the outside? :s
  10. why would it be the cambelt? hes hasnt touched that. water pump runs on the same belt as the alternator. chances are you've put something back on wrong like a vacuum pipe or left a vac pipe off somewhere
  11. somali pirates have extended he rope on their hooks and designed massive ladders
  12. have you had it aligned or checked to know if the camber is the same both sides, or 4 wheels aligned to make sure its tidy?
  13. theres supposed to be a rubber o-ring around it aswell this happened to mine just before a dyno run, couldnt get it to boost past 0.5
  14. spotted you at swansea marina silver bbs looked quality was gunna say hello but didnt want to make things awks because you were with your girlf aha! im sure ive seen it before at a south wales meet but wasnt hundred percent. i was in the american football top walking infront of you for a bit lol ryan
  15. Loving the rocker cover dude Dat spec list.
  16. id say de-black the rear lights, and get some glanza ones without the reverse light part on and get top and bottom sidelights like this but with pre facelift glanza rear lights
  17. welcome buddy! loving the username! brings back some old school playstation memories haha
  18. It's probably hitting fuel cut mate. Do you have a boost gauge and or controller fitted? Welcome to the club
