My toyota mapsensor is reading much more boost than the greddy one. for example greddy sensor sees 20psi and the toyota map sensor reads 31psi! whats happening?
where do you have them connected? it the greddy sensor genuine?
were they always this far out? is one of the sensors broken?
from what i've seen they are usually within 1 psi in terms of reading...very close
what is your boost gauge reading for a comparison?
maybe the map sensor needs changing....is there someone close-by that you can borrow a map?
do you get any codes from the stock ecu?...i think map is code 34
i dont recall the stock map being able to read that high anyways....somehow 1.2bar comes to mind...but i could be wrong
how are you able to read the stock map sensor?
Edited by gorganl2000
Your emanage scaling will be for the 3bar greddy unit probably
Your still just using a 5v sensor
But the voltage output on one sensor doesn't equate to the same pressure on a different sensor
Phil
ok, just looked at some old emu datalogs, i see the stock sensor reading around 214/218kpa when selected...on some full boost runs....which is about 31psi as you mentioned ....while the greddy sensor is reading the correct throughout, which is far less boost than what the stock sensor reading on the emu is showing
so i'd assume the stock sensor is not calibrated for the greddy to read properly...or maybe try changing the unit/scale and see if it reads better, but i doubt it would make a difference
