Hi guys,
Which throttle position switches fit our throttle bodies but is variable rather than idle and wide open throttle?
Thanks
Skyline gtr denso sensor fits straight on but you just need to tap two holes for the bolts to hold it in place
Unbelievably the two holes are already supplied drilled on the stock throttle body to make it extra easy
Phil
You can just Unpin and stick the pins into the stock connector
Or nip the connectors of and solder them up.
Phil
  • 2 weeks later...
