The instructions say to connect to the coil + and coil -
Does anyone know what colours these are on a ep82 4efe?
Red to black then
Black to Blue then
Blew to bits.
Best thing I've ever see Luke. Haha actually cried with laughter. I do hope it's not a JDM Ep82 n/a
On a serious note when I fitted a OMEX rev limiter to my Glanza it cracked my ring lands and it's a pain in the arse changing pistons or even a compleat engine just for a few bangs pops and flames.
I have no interest in pops and flames. Its a competition car with a newly built engine. Ive been running no rev limiter but that ended with a rod through the block on the last engine so want to safely limit it.
Were you using hard or soft cut?
I haven't a clue about electronics so am not sure what wire on the dizzy to use since there is no red and blue on it. Maybe I will ask elsewhere.
They can be switched to soft cut.
Did you connect the coil (-) to earth on the body? Cant see a negative on the coilpack on any wiring diagrams
