Anyone using Ecumaster ?
Yeah I had one in my starlet. Road mapped it myself on 4efe-t so don't have power figures. Even the Det3 piggyback is a semi standalone as is fully takes over fuelling and just piggyback timing.
The full standalone EMU is an unbelievable piece of kit though and well worth the extra doh.
  On 4/29/2016 at 1:50 PM, richardc9052 said:
Depends which way you want to wire it in. Fuel implant (standalone fuelling) or standard client (more like an rsm or AFR)
just using it for controlling bigger injectors on the mines racing ecu as i have no pfc anymore
and pm coming your way
And it works off all standard sensors etc and the standard ECU stays put meaning you keep diagnostics.
Has launch control, boost control (if you buy a solenoid), road dyno, data logging, live map adjustment, switchable maps etc I could go on
  On 4/29/2016 at 6:09 AM, SydesGT said:
Turbo-fever Hi mate you must of come when my black GT was in the workshop?
Yes mate I went up with a friend as they just fitted one to his supra engined BMW and caught the starlet and had a little nose around lol he was fitting one to yours I believe ? What do you think of it ? And nice gt aswell by the way
  On 4/29/2016 at 3:02 PM, 5e colin said:
no i will loose like 1000rpm over the stock ecu richard as the stock ecu is set to 7.2 no piggy can raise the rpm as far as i know
Your a mad man Colin
What are you doing up at 8200rpm?
Phil
as far as i know emu raises rpm limit...but takes a bit of messing around iirc
