iano21 Posted May 5, 2016 Share Posted May 5, 2016 I thought I found thread on here where somebody did this but can't find it now. Anybody point me in d direction?Thanx Quote Link to post Share on other sites
iano21 Posted May 7, 2016 Author Share Posted May 7, 2016 nobody point me in a direction?? throttle bodies or anybody done carbs to a good result, runner lenght etc?? Quote Link to post Share on other sites
richardc9052 Posted May 7, 2016 Share Posted May 7, 2016 Use triumph tt600. Cut a standard Mani Down and connect the two using reinforced silicone joiners. Make a throttle cable bracket, make a bracket to hold the itbs, use thin tin plate to fit the Toyota tps to the triumph itbs. Quote Link to post Share on other sites
Chris Green Posted May 8, 2016 Share Posted May 8, 2016 Or do this... Quote Link to post Share on other sites
Stu Posted May 9, 2016 Share Posted May 9, 2016 The TPS pick up is different pm the 4age throttle body, so if your using the stock ecu, you will need to adapt on the 4e/5e TPS somehow. The 4age TPS runs off "fingers" where as the 4e/5e TPS sits over the butterfly D shaft. Quote Link to post Share on other sites
iano21 Posted May 9, 2016 Author Share Posted May 9, 2016 (edited) Or do this...What throttles are they?Thanx for d help Edited May 9, 2016 by iano21 Quote Link to post Share on other sites
iano21 Posted May 17, 2016 Author Share Posted May 17, 2016 well got a set of tt600 throttle bodies for good value so going to give them a try. . just wondering what runner lengths people are using?? or trial and error ha thanx Quote Link to post Share on other sites
richardc9052 Posted May 17, 2016 Share Posted May 17, 2016 I used the calculator on the jenvey sight. You need 300mm from head to inlet side of throttle body. That will give you top 3rd of 7krpm. 350mm gives you mid to top end, 400 gives mid, 450 bottom to mid, 500 bottom. With the space in the bay you will probably end up 400 max. I went with 330mm but I did plan on fitting trumpets to bring that closer to 400. Never got round to it. 330 didn't bring the power band low enough for me so I'd definitely try to go as long as you can fit. Quote Link to post Share on other sites
SKINY Posted May 18, 2016 Share Posted May 18, 2016 been looking at the tt600 bodies myself now , 60ish quid seem the rate on the bay of flea. The noise from them is sexual Quote Link to post Share on other sites
