Recon turbo, new turbo set up on my charade, similar to starlet. Replaced the turbo for a recon as no boost and suspected turbo. New recon turbo in and still no boost. Car cuts out with intercooler pipes blocked which indicates no boost leaks. External wastegate sealing ring in.
Ive swapped so many turbos on my starlet i thought i could solve it. Got me stumped, turbo primed with start up oil that came with it and prined without efi like starlet.
Its a garret gt17, rotated the turbo housing slightly also. Any more things to try?
The wastegate welded properly ? And it sealed alright after rotating it ? Don't know much lol just throwing a couple things out there
Ya might be as well welding the whole wastegate shut completely any leak or if it's big enough y'all get nothing man any whistling noises when your driving it ?
