Ollieh17 Posted May 28, 2016 Share Posted May 28, 2016 Recon turbo, new turbo set up on my charade, similar to starlet. Replaced the turbo for a recon as no boost and suspected turbo. New recon turbo in and still no boost. Car cuts out with intercooler pipes blocked which indicates no boost leaks. External wastegate sealing ring in.Ive swapped so many turbos on my starlet i thought i could solve it. Got me stumped, turbo primed with start up oil that came with it and prined without efi like starlet. Its a garret gt17, rotated the turbo housing slightly also. Any more things to try? Quote Link to post Share on other sites
starletezy Posted May 28, 2016 Share Posted May 28, 2016 Sounds like a weird one have you tried looking into weather there's a problem with the waste gate ? Quote Link to post Share on other sites
Ollieh17 Posted May 28, 2016 Author Share Posted May 28, 2016 Its brand new from TD, theres no exhaust from the screamer to suggest its leaking Quote Link to post Share on other sites
5e colin Posted May 28, 2016 Share Posted May 28, 2016 is the proppeler moving freely ?? try moving it with fingers Quote Link to post Share on other sites
Ollieh17 Posted May 28, 2016 Author Share Posted May 28, 2016 Yeh moves fine Quote Link to post Share on other sites
Bug679 Posted May 28, 2016 Share Posted May 28, 2016 The wastegate welded properly ? And it sealed alright after rotating it ? Don't know much lol just throwing a couple things out there Quote Link to post Share on other sites
Ollieh17 Posted May 28, 2016 Author Share Posted May 28, 2016 Ive tack welded the actuator bracket in place seems to seal good. Im not if i could have affected anything rotating it? Quote Link to post Share on other sites
Bug679 Posted May 28, 2016 Share Posted May 28, 2016 Ya might be as well welding the whole wastegate shut completely any leak or if it's big enough y'all get nothing man any whistling noises when your driving it ? Quote Link to post Share on other sites
Ollieh17 Posted May 28, 2016 Author Share Posted May 28, 2016 Praying to god its not a fucked turbo again Quote Link to post Share on other sites
fiddlersport Posted May 29, 2016 Share Posted May 29, 2016 Turbo rotating freely ?Primed turbo prior to installation ? Quote Link to post Share on other sites
Ollieh17 Posted May 29, 2016 Author Share Posted May 29, 2016 Yup primed and filled with turbo start oil that came with it. Turbo spins fine.i think it may be the wastegate Quote Link to post Share on other sites
JamesD89 Posted May 29, 2016 Share Posted May 29, 2016 Wastegate spring too strong maybe? how much boost you trying to run? Not familiar with the Charade but seems strange when everything is new or rebuilt. Quote Link to post Share on other sites
Ollieh17 Posted May 29, 2016 Author Share Posted May 29, 2016 Its 0.8 spring. Goes from -0.5 up to just below zero but no further.i think the turbos shot Quote Link to post Share on other sites
adzy Posted May 29, 2016 Share Posted May 29, 2016 Pre turbo exhaust leak or internal wastegate not closed properly? Quote Link to post Share on other sites
Ollieh17 Posted May 29, 2016 Author Share Posted May 29, 2016 Sorted it. Silicone hose inside the air filter was pushed in too far and sucking against plastic Quote Link to post Share on other sites
Bug679 Posted May 29, 2016 Share Posted May 29, 2016 Nice one man glad it's a easy fix for you 👍🏻 Quote Link to post Share on other sites
haggis Posted May 29, 2016 Share Posted May 29, 2016 i had exact same problem last week haha. filter was bottomed put . schoolboy error ;) Quote Link to post Share on other sites
starletezy Posted May 29, 2016 Share Posted May 29, 2016 Sometimes the most simple things leave us baffed lol glad you got it sorted mate Quote Link to post Share on other sites
