5e colin Posted June 8, 2016 Posted June 8, 2016 hey lads i totally fucked up a helicoil thread like a little prat im totally fucked now and came accros timeserts but there prices are just rape prices compared to helicoils any 1 know where they sell cheap sets not like 80/100$ for a tiny set any help appreciated as its a customers car Quote
lukEp Posted June 8, 2016 Posted June 8, 2016 I presume this is what your asking for. EBay 251530222568 Quote
5e colin Posted June 8, 2016 Author Posted June 8, 2016 no thats just a standard helicoil luke i need those serts there like a """ example""" m12 bolt with a m10 thread inside of them of solid material not wire like coils are Quote
Bug679 Posted June 8, 2016 Posted June 8, 2016 This any use to ya man http://www.theinsertcompany.com/steel_self_threading_inserts.php Quote
5e colin Posted June 9, 2016 Author Posted June 9, 2016 looks like it anyways going to contact them Quote
5e colin Posted June 9, 2016 Author Posted June 9, 2016 i found these http://www.ebay.ie/itm/Threaded-Insert-Self-Cutting-Stainless-Steel-M3-M10-/361324242851?var=&hash=item54209a67a3:m:mCyI95udHe1cCsXounQF9Hg will they do as there ss is it ok in aluminium ??? Quote
Starlet__SR Posted June 9, 2016 Posted June 9, 2016 i found these http://www.ebay.ie/itm/Threaded-Insert-Self-Cutting-Stainless-Steel-M3-M10-/361324242851?var=&hash=item54209a67a3:m:mCyI95udHe1cCsXounQF9Hg will they do as there ss is it ok in aluminium ??? Aslong as you lubricate them with moly or copper grease to stop oxidising. Quote
5e colin Posted June 9, 2016 Author Posted June 9, 2016 ^^^^ thanks for the info got a tin of copper grease will order some see how i get on Quote
AdamB Posted June 9, 2016 Posted June 9, 2016 What's it for? Steel and Alloys have different expansion rates, so if its for a part that gets hot thats something to consider. Quote
5e colin Posted June 9, 2016 Author Posted June 9, 2016 for an aluminium head adam i fucked up a helicoil for fuck sake dont know how i managed to do that thread was pulled out bolt was spinning in its thread so i did a helicoil job and fucked up inserting the bolt in the coil making a mes of it now cant get new bolt in it Quote
triple j Posted June 9, 2016 Posted June 9, 2016 The block is cast I would be sticking with the steel. U could even strip it with the bolt when u torque it, if it doesn't happen then it will if u ever have to take it out again. Quote
5e colin Posted June 10, 2016 Author Posted June 10, 2016 J it is to go in aluminium not the headbolt Quote
pdg190 Posted June 10, 2016 Posted June 10, 2016 (edited) Have you looked at keenserts? Used them a lot whilst machining for judd. Always found them to be spot on for aluminium. Edited June 10, 2016 by pdg190 Quote
5e colin Posted June 10, 2016 Author Posted June 10, 2016 (edited) Have you looked at keenserts? Used them a lot whilst machining for judd. Always found them to be spot on for aluminium. thank you for the tip went surfing and found the correct size m10x 1.25 sweeeet : / the other brands are al m10 x 1.5 http://www.ebay.co.uk/itm/10mm-M10x1-25-KeenSert-Thread-Repair-Insert-10x1-25-One-Piece-Ships-Fast-/151657410505?hash=item234f7c6fc9:g:ZogAAMXQI5tRgcNp going to order 1 and see Edited June 10, 2016 by 5e colin Quote
Johnboy GT Posted June 10, 2016 Posted June 10, 2016 You can pull the helicoil out, re dress it with the tap and try again Colin? John Quote
5e colin Posted June 10, 2016 Author Posted June 10, 2016 how do you get it out john ??? thanks for tip Quote
Johnboy GT Posted June 11, 2016 Posted June 11, 2016 See the start of the helicoil at the top, flick it outwards with a screw driver so it's covering the hole, long nose pliers and pull it out, it'll come out like a spring. Not a problem budJohn Quote
Flaminsam Posted June 13, 2016 Posted June 13, 2016 We use time certs at work. Brilliant bit of kit from wurth. Thing is they are pretty expensive! 😕 Quote
5e colin Posted June 13, 2016 Author Posted June 13, 2016 yes seen them look very good but very dear for a little kit over 100£ Quote
