paddy Posted June 15, 2016 Posted June 15, 2016 Right just spent the last week taking the head off my glanza, changed the valve stem oil seals (victor rezinz ones) cars all back together now, fresh headgasket, but its still smoking, its not as bad as it was before, as soon as u give it a little boost, then let of the throttle for a few secs then put your foot back on again u get a puff of smoke out the back. its not as bad as it was before the seals were done but its till smoking, anyone got any suggestions? could piston rings or turbo cause similar symptoms as valve stem seals? im running a gt engine with about 85k miles on it, Td04, jam ecu running .8 (rarely run over, never over 1 bar) car runs very well, but it smokes a bit. turbo core was replaced about 4000 miles ago Quote
daniel_g Posted June 15, 2016 Posted June 15, 2016 PCV valve on the rocker can cause smoke issues.Unless youve got a race spec rocker and catch tank. Quote
paddy Posted June 16, 2016 Author Posted June 16, 2016 I fitted a Chinese turbo core, to be honest it's pretty good I don't think it's that, valve guides sound like they could be the problem, didn't think of this. Would explain having similar symptoms to stem seals. Can the guides be replaced? I have a PCV valve fitted, it's not blocked but could this still cause it to smoke with a td04? Quote
StuDoc 72 Posted June 16, 2016 Posted June 16, 2016 Does it puff smoke when you first start it after it has been lying overnight? Quote
paddy Posted June 16, 2016 Author Posted June 16, 2016 No I'd doesn't only when the engines warm, usually after a bit of boost Quote
StuDoc 72 Posted June 16, 2016 Posted June 16, 2016 If it doesnt puff smoke after its been lying then its not the valves. Quote
paddy Posted June 16, 2016 Author Posted June 16, 2016 I put it to the test again on my drive home from work, it's only after boosting it, drive off of boost its fine. I've just got rid of the PCV valve and replaced it with a breather but I'm thinking turbo Quote
gazza g Posted June 21, 2016 Posted June 21, 2016 im having this issue, its fine no smoke on startup, no smoke driving or coming on boost but if you say do 40mph in 3rd let the revs drop and then touch throttle a big cloud of greyish smoke comes from the exhaust, if i sit revving the car no smoke can be seen from the back of the car and idle shows no smoke either. i dont think its valve seals as you said it doesnt smoke when started up, anyone else have any ideas what it could be? Quote
funny onion Posted June 21, 2016 Posted June 21, 2016 I've had this a few times, turned out to be turbo seals every time Quote
gazza g Posted June 21, 2016 Posted June 21, 2016 worn rings would give smoke pretty much all the time Quote
richardc9052 Posted June 21, 2016 Posted June 21, 2016 Im sorry but its your turbo seals as I already stated. You are in denial as you just changed the cartridge. but come on it was a cheap chinese one. You win some, you lose some. Quote
paddy Posted June 22, 2016 Author Posted June 22, 2016 I'll get the turbo replaced and go from there. Thanks for the help Quote
Flynn Posted June 22, 2016 Posted June 22, 2016 Let us know how you get on mate, got 2 cars with similar issues! Quote
paddy Posted August 21, 2016 Author Posted August 21, 2016 Just replaced my turbo, fitted a melett TD04 core at a cost of £170 and still having the same problem! All this time and effort and getting no where, so far replaced PCV valve with a propper breather, new valve seals, new head gasket, new turbo core. Running out of ideas now, so frustrating! Quote
Ollieh17 Posted August 21, 2016 Posted August 21, 2016 Left over oil from old core?sure its defo burning oil? Quote
paddy Posted August 21, 2016 Author Posted August 21, 2016 I hope so done 30 miles now and it's stil the same, you can smell the oil, the smoke is grey ish but doesn't use a drop of water Quote
Fozzie Posted August 21, 2016 Posted August 21, 2016 Why don't you do a comp test, that'll tell you if it's the piston rings or not? Quote
paddy Posted August 22, 2016 Author Posted August 22, 2016 (edited) I'll get a compression tester and have a go, does it matter which way round the water lines go on the turbo? Also I've read about having a restricter on the oil feed to the turbo, can anyone shead any light on this? Edited August 22, 2016 by paddy Quote
5e colin Posted August 23, 2016 Posted August 23, 2016 on a ct9 there is no restrictor unless a custom inline jobby other turbos 1.5mm for jouirnal bearing and 1mm restrictor for bal bearing Quote
funny onion Posted August 23, 2016 Posted August 23, 2016 Water lines don't matter either way around, personally I've never ran coolant to any of my turbos. As above, next thing I would do is a compression test. it would be a long shot maybe but if you could get hold of a bore scope have a look down see what you can see? but compression test should tell you a bit. I know it's frustrating but don't give up you'll find it eventually! Quote
Ollieh17 Posted August 23, 2016 Posted August 23, 2016 Journal bearings dont really need restrictiors, escpecially on a new, journal bearing turbo.starlets dont really run high oil pressure and the oil feed i imagine is around 4an so that provides a restriction.Have you checked your oil drain setup? Only blockages? Uphill areas? Tight bends? Quote
paddy Posted August 23, 2016 Author Posted August 23, 2016 I was digging through the forum last night, found a post with my same problem, he said it turned out to be piston rings. Shame really as the car runs very well. My oils drain set up is all fine, I'll fit some rings and replace bottom end bearings at the same side to be on the safe side, thanks for the help everyone. I'll update the post once fitted Quote
