I'm in Ireland so unfortunately we can't get a friendly tester so I was wondering if an EW and screamer pipe would pass nct ? Will most likely be a hybrid CT9 maybe TD04. I don't want to be having to change setups for the yearly test as it will be my everyday driver.
Thanks in advance
Joe
  • 2 weeks later...
Like said above. If the w/g is facing down jus unbolt the screamer. They wont ever make spring pressure boost unless on a road test there for it will always be a closed circuit.
Your issue is your lack of cat is it not?
Will be going td04 with ewg later on. Ct9 for the time being. But with the Td04 I'll be getting a removable hi-flow cat made to go under the car and a de-cat to suit
