5e colin Posted June 22, 2016 Posted June 22, 2016 hey lads i have a question for the td experts i have the 2 turbos mentioned above and want to make a hybrid out of it plan is to use the tdo4l core and compressor side take out the turbine shaft and fit the tfo35hm shaft in its place when thats done. fit the td core back in to the tfo35hm exhaust housing ???? is that going to work ?? Quote
kbond Posted June 22, 2016 Posted June 22, 2016 This is what I am running on my gtLiam at midland turbo built it for me with an 11blade billet wheelMapped at td with 266hp at 1.4barPulls very well, spool of a tf but near power of a td Quote
gorganl2000 Posted June 22, 2016 Posted June 22, 2016 question collin....can the tf035 exhaust housing be modified to fit the td04l?if so, this should produce similar results to what you have planned, be more balanced and less work required didnt someone do a comparison messing around with the back ends sometime ago? kbond should have benefited from the better flowing billet wheel----which you wont be doing as part of your project Quote
5e colin Posted June 22, 2016 Author Posted June 22, 2016 (edited) yes androo used a tfo35hm housing and bored it out to fit a tdo4 core + tdo4 turbine wheel i want to keep the smaller tf0 turbine shaft for the uber fast spool might look into billet stock tdo4 wheel on the compressor side the inducer are same size almost td04/tfo35 the exducer on the compressor wheel tho is a good bit bigger on the tdo4 so should aid spool even more if i did my reading right ?? Edited June 22, 2016 by 5e colin Quote
gorganl2000 Posted June 23, 2016 Posted June 23, 2016 that 4cm2 tf035 exhaust housing approximates an ar of 0.25.....vs the stock td04l a/r of 0.41 (6cm2)that in itself is a massive drop in housing size....hence faster spool (and obviously restricted top end, but that is not your aim here) for the simplicity of it...it maybe your most economical option for experimentation purposes the billet wheel,,,depending on size can improve flow slightly or cause an imbalance/choke based on the leaderboard:1) billet td04l makes approximately 298/303bhp at TD running 20psi (based on 7 results) 2) td04l makes approximately 280/296bhp at TD running 20psi (based on 6 results) so not much difference there really for the billet wheel----maybe 5% more flow....i suspect the 6cm2 back end of the td04l is a restriction at this point 3) kbond previously made 203bhp at 13psi using the tf035 at TD (was it stock at this point??)...but above with the billet wheel added the car made 266bhp at 20psi...so boost has been turned up as well in this equation (specs of billet wheel unknown)----------according to the build tread he gained 1000rpm better response and lost about 17bhp compared to the td04l @1 bar at TD 4) ct9 hybrid made 254bhp at 17psi at TD...while a blitz k1 made 218bhp @ 15psi at TD---these are just for reference sake now for the estimation stuff (guess work lol)....so not knowing the maximum limits of the stock tf035...let's say its capable of 1.2/1.3bar max,,,it could possible create 220/230bhp...and a stock td04l combined with tf035 4cm2 housing may be around that same limit 230/250bhp due to the 4cm2 housing but bigger turbine wheel and you benefit from the better response (possibly 500/1000rpm) vs a stock td04l assuming each set up is properly tuned (ignition and fuel) well...just throwing some thoughts at you 5e colin Quote
5e colin Posted June 23, 2016 Author Posted June 23, 2016 thanks for the write up , i will only be running 1.1bar max on my boosted GI block i am not worried about choking up top as i had a stock tfo35hm before with my acis and pulled really hard to the limiter with no drop of when acis opened thats why i thought using the tdo4l setup with the bigger exduser on compressor side will make it spool even faster the ultimate pocket rocket turbo Quote
gorganl2000 Posted June 23, 2016 Posted June 23, 2016 is your gi block (4efe n/a) high compression? if so, i'd for sure use the td04l with tf035 back end at minimum for the 16psi you plan to run with the high compression you shouldn't lose much response over the stock tf035,,,with the possiblity of making slightly more power Quote
5e colin Posted June 24, 2016 Author Posted June 24, 2016 the pistons are swapped over to 4efte pistons the rods are the original "" fat "" gi rods Quote
gorganl2000 Posted June 24, 2016 Posted June 24, 2016 ok...you basically run a "4efte"---lower compression 8.2:1 so you lost the high compression benefit of the n/a 4efe response wise....but gain a bit on knock resistance Quote
ramses Posted July 11, 2016 Posted July 11, 2016 4e na High compression ,is very awsome with td04... Quote
daniel_g Posted July 11, 2016 Posted July 11, 2016 4e na High compression ,is very awsome with td04...Certainly is, thats what i run atm, only 0.6bar though. Quote
richardc9052 Posted July 11, 2016 Posted July 11, 2016 Certainly is, thats what i run atm, only 0.6bar though.Whats it like Quote
daniel_g Posted July 11, 2016 Posted July 11, 2016 Whats it likeFeels pretty good in the 4paw, minimal lag, powers there when you need it. Off boost driving is decent too. 0.6 seems safe enough for now its just spring pressure. Got a lightweight fly to fit soon.Keep looking at 9.1 Wisecos.. Quote
5e colin Posted July 11, 2016 Author Posted July 11, 2016 so the good ol tfo would be even better spool a lot faster ha ha Quote
richardc9052 Posted July 11, 2016 Posted July 11, 2016 (edited) I ran 4efe on ct9 and a hybrid both without an intercooler lol so if you want to talk about no lag hahahaJust hoping tf will be a decent jump from ct9 I will be running 0.8 on 100ps 4efe. Edited July 11, 2016 by richardc9052 Quote
5e colin Posted July 11, 2016 Author Posted July 11, 2016 its a decant jump from ct9 but get rid of the restricting 4efte manifold its a chocking hazzard up on the rev line Quote
richardc9052 Posted July 11, 2016 Posted July 11, 2016 It will be staying for now lol can't afford to upgrade it Quote
Androo26 Posted July 12, 2016 Posted July 12, 2016 Hmmm well I can say this .... Im now running an internally stock 5EFE 9.5:1 comp with a TD04-13T with a 4cm rear housing machined to suit the td04 exhaust wheel and it is simply awesome. But the only drawback is thatI can only run 10psi using pump 98 gas. Still goes very well though. Can only imagine how good it would be using E85 and 15 pounds. I should do some data logs on spool. I know I get full 10 pounds before 3k Quote
ramses Posted July 12, 2016 Posted July 12, 2016 Hmmm well I can say this .... Im now running an internally stock 5EFE 9.5:1 comp with a TD04-13T with a 4cm rear housing machined to suit the td04 exhaust wheel and it is simply awesome. But the only drawback is that I can only run 10psi using pump 98 gas. Still goes very well though. Can only imagine how good it would be using E85 and 15 pounds. I should do some data logs on spool. I know I get full 10 pounds before 3k are you sure ?? i can go over 14 psi in high compression Quote
Androo26 Posted August 13, 2016 Posted August 13, 2016 Rightio then lads ive done some data logs on spool up with this 4CM TD04 hybrid im running. For those that dont know my setup its a rebuilt N/A 5EFE completely stock 9.5:1 comp. Turbosmart 38mm External waste gate. 4EFE Intake manifold. It runs a GFB Atom bleed valve (very basic) so this is about as slow/ linear to build boost as your going to get with no waste gate trickery at all. The run was performed in 3rd gear, foot flat to the floor from 2000 rpm till redline 6K 1 psi 2000 rpm3 psi 2120 rpm4 psi 2250 rpm5 psi 2380 rpm6 psi 2410 rpm8 psi 2560 rpm I might just add that using a bleed valve the gate at this point is almost all the way open as it going to get. So if it were using an EBC you could still have the gate completely closed if you wanted making use of all the exhaust gas9 psi 2620 rpm making it spool faster again. But Ive chosen the bleed valve because its more gradual and better for traction. (still awesome response on the street)10 psi 2950 rpm Quote
