another question lol what boost will the stock ignition cope with
i've personally seen the stock ignition system handle boost up to 1.5 bar with no issues on gt28/td05 sized turbos...which as said above tend to give about 350bhp
the individual components would need to be in good condition--plugs, wires, coil, distributor, igniter, coil
and your plugs may need to be gapped appropriately/smaller at higher boost levels to avoid blow out
others have claimed to run more than 1.5bar...the most i've heard is 2.0 bar on a gt28....but at these boost levels, you tend to have other issues to worry about such as head bolts, h/gasket, etc---IF they are stock
Edited by gorganl2000
Copper NGK (part number for fiesta rs turbo)£2each
Gapped to .6
If your wanting to run with the stock ignition.
Phil
And you rate these Phil Eh. The heat range 7 ngk no good??
It was pushing 1.93 bar had no issue but the boost was tailing off so Av ordered a stronger wastegate spring see if that was the issue just a friend said he was surprised I had no issue that was the reason for the question thanks for reply lads
