Starlet__SR Posted July 23, 2016 Posted July 23, 2016 You don't want to be going over 75mm in all fairness. The spacing between cylinders isn't all that thick to start with. Quote
richardc9052 Posted July 23, 2016 Posted July 23, 2016 In fairness ive seen a member running 76mm.Cc depends on a lot of things but assuming its completely factory spec but 75.5 your looking close to 1400cc Quote
Starlet__SR Posted July 23, 2016 Posted July 23, 2016 In fairness ive seen a member running 76mm.Cc depends on a lot of things but assuming its completely factory spec but 75.5 your looking close to 1400ccI'm not saying its impossible. But you're running very close to the safe limits. Quote
AdamB Posted July 23, 2016 Posted July 23, 2016 (edited) 1386.071 ccStock stroke What is it you're trying to achieve mate? I wouldn't advise it. Edited July 23, 2016 by AdamB Quote
mini valver Posted July 23, 2016 Author Posted July 23, 2016 Not trying to achieve much was just a thought I had Quote
daniel_g Posted July 23, 2016 Posted July 23, 2016 Who does 75.5mm / 76?75mm looks fuckin close enough as it is. Quote
Calum122 Posted July 23, 2016 Posted July 23, 2016 You seen those Honda builds where the sleeves look as though they are actually touching. I remember reading once that he actually had a sleeve drop and destroy is B18 lol. Savage build though Quote
