marki7 Posted September 3, 2016 Posted September 3, 2016 Ok so with all the niggly bits going on with my engine am pulling it out and refreshing it all. Parts so far*head gasket set inc new head bolts*full hose kit*new crank pulley*cambelt kit and water pump*new oil pump*new mounts*full service kit inc belts*oils and high temp gasket sealant *new pcv valveNot sure of what else I need but would like to get every last bit before starting any advice would be much appreciated thanks guys an girls Quote
turbominicooper Posted September 3, 2016 Posted September 3, 2016 You don't really need to pull it out to do the above but if u r may aswel do rings and bearings. Quote
5e colin Posted September 3, 2016 Posted September 3, 2016 ya you got almost everythingt there to do a FULL resto on the engine Quote
fiddlersport Posted September 4, 2016 Posted September 4, 2016 Valve stem sealsCrankshaft seal (gearbox and pulley side)WaterpumpRocker cover gasket (genuine) Quote
patman Posted September 4, 2016 Posted September 4, 2016 Would personally got for a full engine geniune gasket kit so comes with all seals, gaskets etc Quote
marki7 Posted September 5, 2016 Author Posted September 5, 2016 Valve seals came in the kit as did rocket cover gasket all genuine....just placed the order for crankshaft seals 👍Got 1lt of black hammerite to paint the block and 4 hammerite rattle cans(silver) for everything else Quote
turbominicooper Posted September 5, 2016 Posted September 5, 2016 Do the lot mate https://youtu.be/U1XRdi1LkTw Quote
marki7 Posted September 5, 2016 Author Posted September 5, 2016 Do the lot mate https://youtu.be/U1XRdi1LkTw Good video that mate not sure about the backing music lol Quote
fiddlersport Posted September 5, 2016 Posted September 5, 2016 If you have the funds like phil suggested go for a forge ? Quote
turbominicooper Posted September 5, 2016 Posted September 5, 2016 Good video that mate not sure about the backing music lol Quote
marki7 Posted September 15, 2016 Author Posted September 15, 2016 So got the engine out today..bit of work needed put came out hassle free. Found a toms fly wheel when we split the box turbo is shagged so on the hunt for a ct9..now left with a messy engine bay what's best way to tackle any help will be much appreciated cheers guys and girls Quote
Ollieh17 Posted September 15, 2016 Posted September 15, 2016 No nonsense degreaser from screwfix, cheap and works a treat Quote
marki7 Posted October 10, 2016 Author Posted October 10, 2016 Been flying along nicely with this up until now....changing the mounts and am sort of scratching my head at the rear one how do u get it of and do I have to press the old rubber out to make way for the powerflex bush Quote
