aleximport25 Posted September 14, 2016 Share Posted September 14, 2016 how do all,does anyone have any useful info to help me wire in my det 3 to my 3 plug ecu extension harness.i have the manual and a basic pin out for both the DET3 and the standard ecu. thanks in advance Alex. Quote Link to post Share on other sites
TrisK Posted September 14, 2016 Share Posted September 14, 2016 can you post the DET3 pin out? and are you 98 spec wiring? Quote Link to post Share on other sites
Ollieh17 Posted September 14, 2016 Share Posted September 14, 2016 You planning on using the fuel implant? Quote Link to post Share on other sites
aleximport25 Posted September 14, 2016 Author Share Posted September 14, 2016 can you post the DET3 pin out? and are you 98 spec wiring? i shall get it when im home from work dude :-) You planning on using the fuel implant? this is where im unsure what are people recommendations ? Quote Link to post Share on other sites
richardc9052 Posted September 14, 2016 Share Posted September 14, 2016 If you just want it for launch control then go standard client. Otherwise go fuel implant. Stand-alone fuelling gives very good map possibilities. I would say, given the amount of combinations of inputs I would just let the person mapping it do the wiring. Plus the fact that in fuel implant mode you can't drive the car without a map so you would have to tow the car there if you hardware it. Quote Link to post Share on other sites
aleximport25 Posted September 14, 2016 Author Share Posted September 14, 2016 Cheers dude, I'll go for the stand alone fueling, the the two mappers I've been speaking are both local one is based in my village and does road mapping the other is about 10 miles away with rollers, they both would like a copy of the software to have a play with before hand. I was hoping to wire the det3 into the extension harness and run a vac line ready then just plug in at the mappers. Quote Link to post Share on other sites
aleximport25 Posted September 14, 2016 Author Share Posted September 14, 2016 can you post the DET3 pin out? and are you 98 spec wiring?It's 98 spec wiring dude Quote Link to post Share on other sites
akyakapotter Posted September 14, 2016 Share Posted September 14, 2016 ive herd if you throw the wiring at it it will do it its self Quote Link to post Share on other sites
richardc9052 Posted September 14, 2016 Share Posted September 14, 2016 The software is free to download online. You have to use the correct program so you will want them to use the fuel implant client Quote Link to post Share on other sites
richardc9052 Posted September 14, 2016 Share Posted September 14, 2016 Fuel implant software: http://www.ecumaster.co.uk/pobierz/det3/EcumasterDET3_FI_1_30.exeUser manual:http://www.ecumaster.co.uk/pobierz/det3/Digital%20ECU%20Tuner%20III%20-%20FIT%20Manual%20English.pdfUsb Driver:http://www.ecumaster.co.uk/pobierz/other/CDM20824_Setup.exe Quote Link to post Share on other sites
aleximport25 Posted September 14, 2016 Author Share Posted September 14, 2016 ive herd if you throw the wiring at it it will do it its self If only 😂 I don't mind a bit of wiring. Quote Link to post Share on other sites
aleximport25 Posted September 14, 2016 Author Share Posted September 14, 2016 Cheers rich, I've printed off a manual and just going to burn them to disc and drop them off, on the plus note I found on the ecumaster forum that they use the same plug as a pc motherboard power supply, just cut one off my old tower. Quote Link to post Share on other sites
triple j Posted September 14, 2016 Share Posted September 14, 2016 Can this ecu fuel the same as the e manage adding voltage to injector pulse on top of the stock ecu map? Quote Link to post Share on other sites
richardc9052 Posted September 14, 2016 Share Posted September 14, 2016 No that's shit it fuels like a stand-alone Quote Link to post Share on other sites
Ollieh17 Posted September 15, 2016 Share Posted September 15, 2016 Im selling a det3 if anyones looking Quote Link to post Share on other sites
triple j Posted September 15, 2016 Share Posted September 15, 2016 No that's shit it fuels like a stand-alone I would far rather keep the OEM closed loop operation, it will take a lot more work to tune closed loop in this implant mode, if it fuelled this way I would buy one otherwise I would go full standalone. Quote Link to post Share on other sites
Ollieh17 Posted September 15, 2016 Share Posted September 15, 2016 Doesn't it allow the ecu to control idle etc so saves on all the hassle when going standalone Quote Link to post Share on other sites
