Have you had your ecu unplugged or anything?
Mine did this after I put my ecu back in, but after taking it for a drive to let it adjust a bit was fine after
Well it started after it went on a dyno. But the battery keeps going flat as the alternator needs changing. But when I say flat I mean like completely dead. So the ecu has probably forgot itself once or twice.
Sent from my Nexus 6P using Tapatalk
It could be just unburnt fuel coming out, mine only began to do it when I upped the fuel pressure. Have you an aftermarket fpr fitted?
Yeh if it happens after you've just charged the battery back up then that's probably it
Was the car warm, every turbo car i know with decat and exhaust system does this on start up and when cold. My glanza with a side exit used to cover my neighbouts car
If you are 100% sure it wasn't condensation you should probably get it looked at lol.
Car may be up to temp but doesn't mean all condensation has burnt off
Engine could also be warm without the exhaust being warm.
Might be all sitting in the back box which is going to be the coolest part of the exhaust and would need to reach 100 degrees+ to get rid of all condensation.
I'd be 99% sure its condensation if not then your HG is fuuuuuuuu huckkkked.
Is the ECU pnp or programmed?
Overfuelling ?
The black sut coulde have been there a while and now the coldweather has kicked the condensation could be flushing out ?
Just a wild guess
Check the colour of your spark plugs
Good tell tale sign of fuelling
