seems to be the common theme these days with cams I just want it to sound cool so many variables with cams it's not even beneficial on most builds the stock cams are just fine but hay it sound cool
Just spend the money on a good ecu and do then make the idle do whatever you fancy
Phil
Edited by Phil
I actually mistook whitenoises post as a response from you.
Yeah if you know what your after fire away pal.
Though Plenty of suggestions above and your always going to get people's opinions on a forum just one of those things.
I'd say Ivan tighe would be your best bet. Speed vision also makes billets
Depends what's your using them for obviously - but if you just wanna buy cams fire away
Phil
