Looking to purchase some denso 560cc injectors for my glanza theyre high impedance will they fit directly into my car?
Cheers
Taz
Edited by TazzEp91
  • 1 month later...
Non .. there is no horsepower to gain just by swopping 4 injectors, it's more than likely you will loose power.
An injector works by a voltage signal being sent from the ecu. Each voltage corresponds to a pulse time and flow (duty cycle) telling the injector how long to open for and how much fuel to flow.
If you go putting a larger injector into your engine without programming the pulse and duty cycles the ecu will presume the injectors are the same flow and not make corrections for the amount of fuel.
I.e
when a standard injector flows 295cc @100% duty cycle at w.o.t and full boost (6psi),
That's all kinds of good fuelling.
If you take an uprated injector that flows 550cc @100% duty cycle and the ecu asks the injectors for 100% duty. Well, you can imagine the outcome.
I.e
I know that maybe I didnt ask the question properly, my question was what is the power gain after swapping the injector and fine tune the emanage for that particular injector.
Your still not asking the right question
Again the answer is no power gain
Unless you change something else to require that extra fuelling potential
Phil
Phil
Hi Phil,
Sorry im not arguing with you im just trying to increase my knowledge. when you said something else you mean an uprated fuel pump or is there some more things that need changing?
Hi Phil,
No
Prob
Have a read
http://www.physics247.com/physics-tutorial/turbochargers.shtml
Engine is basically an air pump
You want more air moving threw it faster to make more power. Your fuelling just needs tuned to match the air flow.
So you need more air if your going to make power from Additional fuel.
Phil
basically ....
we cant tell you what power you will gain from injectors and a mapping session for multiple reasons:-
1. the air temp on the day does effect how much power you will produce allbeit a small amount 1-2 hp sometimes 5 max
(i work very closely with canems ecus and his dyno is actually at my work, ive seen first hand a hp figure change from first thing in a morning to mid afternoon when the air is hotter ettc)
2 your general engine setup, clutch, flywheel, gearbox, boost level, engine health, plugs,fuelling
3. what fuel your using and where yoou got it from
4 the mapper himself/herself
5 the dyno.
the list is endless and can get even more tedious
but iirc about 260/270 is easily producable on a td04 4e with injestors and a good map.
