SpikeyJp_68 Posted November 27, 2016 Share Posted November 27, 2016 Does the centre stud come out and will I need to drill holes any tap them ? Or will I get away with a gasket and sealer ? Thanks in advance. Quote Link to post Share on other sites
5e colin Posted November 27, 2016 Share Posted November 27, 2016 Screw out the center bolt 🔩 in the 4efe block and bolt on the 4efte oil relocator seal will do Quote Link to post Share on other sites
daniel_g Posted November 27, 2016 Share Posted November 27, 2016 I put one on a 4e block and never bothered tapping it for studs, smear of sealer, didnt leak. Quote Link to post Share on other sites
SpikeyJp_68 Posted November 27, 2016 Author Share Posted November 27, 2016 Screw out the center bolt 🔩 in the 4efe block and bolt on the 4efte oil relocator seal will doTop lad Colin I'd imagine a pair of vicegrips/water pump pliers would work ? Won't be needing it anywayI put one on a 4e block and never bothered tapping it for studs, smear of sealer, didnt leak.Cheers mate Quote Link to post Share on other sites
gorganl2000 Posted November 27, 2016 Share Posted November 27, 2016 I put one on a 4e block and never bothered tapping it for studs, smear of sealer, didnt leak. ..i've done the same on a 5e...never leaked Quote Link to post Share on other sites
