Wondering if it will be okay to use the stock tmic at 1 bar on a ct9? Or would it be safer too run it at 0.8 bar? Will be used for the odd track day ect just cant afford an fmic as well as a map and exhaust manifold. Cheers
Hang out for a fmic imo. They can handle 1 bar just track days...heat... it's rolling the dice. The cooler the engine the better obviously.
Yeah thats true, might just have to skint myself out for a month lol better safe than sorry.
I ran 1 bar on an ARC top mount for 2 years. was absolutely fine.
Only problem is i cant find an arc tmic anywhere lol. Cheers
Just to let you know that is identical to the kit I bought and I can't fault it to be fair for the money. Easy to install if you know one end of a spanner from another, and a pretty good fit with just a bit of modifying to the brackets. Only running 0.8 bar through it at the moment though so can't comment on how well it will be at 1 bar.
