EP70-PT Posted December 31, 2016 Posted December 31, 2016 So, having the oil feed and return figured out, I started to think of ways of doing the watercooling on the CT9, yes I know I could do without it but why not? I don't have CT9's in every corner where I am! xD Since the 4E-FE doesn't share the same thermostat housing as the FTE, I thought about looping the Throttle body water lines to the CT9, would this work? What exactly does the throttle body water do? Could it do without? Cheers Quote
5e colin Posted December 31, 2016 Posted December 31, 2016 the w2ater going tru Tb is so the wax stat softens and closes the hole lowering rpm thats on the turbo tb so think wioll be swame on the na tb fit some T joiners in the lines going to the tb i dont see why it wont work ?? Quote
EP70-PT Posted December 31, 2016 Author Posted December 31, 2016 Or I could just bypass the throttle water feed and put it on the turbo instead, that was my original idea Quote
5e colin Posted December 31, 2016 Posted December 31, 2016 no it will fuck up the tb idle best to keep wax stat watert usage you can bypass ofcourse but in winter it will be cunt to setup as very slowly the tb will heat up and stabilise the rpm Quote
EP70-PT Posted December 31, 2016 Author Posted December 31, 2016 My idle is already weird idk why, it starts at 900 in the morning than raises to 1100 when warm... idk why it's doing this... Quote
5e colin Posted December 31, 2016 Posted December 31, 2016 That be your electronic idler valve doing that not the wax Quote
Rob H@RCH Engineering Posted January 1, 2017 Posted January 1, 2017 You can just fit the thermostat housing from a turbo engine and then you would have the feeds Quote
EP70-PT Posted January 2, 2017 Author Posted January 2, 2017 I'm from France mate, would have to get one shipped, more hassle more wait etc xD Quote
Patches Posted January 4, 2017 Posted January 4, 2017 I'm from France mate, would have to get one shipped, more hassle more wait etc xDFrom experience I would say it's worth the wait to do it right. Express postage surely wouldnt take too long? Quote
