As above some pics please, I'm having my AEM wideband, water temp, oil temp and pressure gauges fitted tomorrow and would like some pics with where you have had yours mounted! Thanks in advance!
Three pod holder on the A pillar for my volt, boost and wideband.
I had so many issues fitting water temperature, oil pressure and oil temperature gauges that I eventually gave up and ripped them out!
So I've had the gauges all plumbed in and wired up, they're mounted on the dash! What are typical readings on oil pressure and wideband? I think I have a problem with the wideband sensor because it will count 111,222,333 etc. Then engine running just go straight to --? with the engine off and ignition on it's will sit at 14.3?
Oil pressure mate do you have it in psi or bar, also did you follow the instructions on how where to put lambda sensor thing in the exhaust, 36 odd inches from turbo and 10 degrees etc
Followed all the instructions! But just can't seem to get it to read, I've seen on a few websites that a few people have had the same problem and seems to be the sensor! I have a PSI pressure gauge! :)
Its a bit busy but i should work well when driving
Water temp on left
Oil pressure in middle
Oil temp on right
Far right AFR with boost controller on top
Edited by 5T4R7ET N/A
  • 3 weeks later...
14 on idle. 10 on boost. Pretty sure she's firing pouring unburnt fuel out the back.
The --- definitely sounds like your sensor isn't connected or is faulty. You'd get some reading even if it's positioned wrong.
Edited by Arnold
