Georgehburroww Posted February 26, 2017 Share Posted February 26, 2017 So basically I'm mid way through a turbo conversion on my starlet sportif, I've got the full inerior and engine loom for a 4efte, I've been looking through the blogs and I'm looking for info about the differences between a 4efe and a 4efte engine. From what I know... things like pistons and conrods are stronger in a 4efte, I've got my old 4efe and am trying to save as much money as possible. Are there any people out there that have used bits off a 4efe that won't effect performance to build a 4efte? Or would it be easier to just buy a used 4efte engine?? Quote Link to post Share on other sites
SRdan Posted February 26, 2017 Share Posted February 26, 2017 Cost wise mate you'll be better off buying a 4efte engine. As this has the stronger rods, Low comp Pistons, stronger valve springs, different inlet, bigger throttle body, the list goes onHaving said that it's pretty easy to turbo a 4efe and get it running right (I have done this) It's all down to budget really Quote Link to post Share on other sites
Calum122 Posted February 26, 2017 Share Posted February 26, 2017 So you can run boost through the 4efe fine, but they run higher compression engines, so you won't be able to run as much boost. Ultimately, you want to save money, either do it properly and go big, spend money. Or do a budget build, accept that it won't withstand the punishment of a factory turbo but enjoy smiles per miles.I think it's around 6PSI on a 4efe, happy to be corrected. You could get 4efte pistons and rods for next to nothing. If the pistons are thick enough, you might be able to have the heads machined down a fraction to reduce the compression, but then this might weaken it too much so you won't be able to boost as high. Quote Link to post Share on other sites
lukEp Posted February 26, 2017 Share Posted February 26, 2017 Run 10-11 psi (max out stock 4efte ecu) on 4efe and it's awesome. Quote Link to post Share on other sites
SRdan Posted February 26, 2017 Share Posted February 26, 2017 If you want to turbo your 4efe give me a message bud. I'm selling all my 4efe turbo stuff including det3 management Quote Link to post Share on other sites
5e colin Posted February 26, 2017 Share Posted February 26, 2017 Run 10-11 psi (max out stock 4efte ecu) on 4efe and it's awesome. x2 very strong engines 4efe Quote Link to post Share on other sites
Rich-k Posted February 28, 2017 Share Posted February 28, 2017 Whats needed to turbo a 4efe? Quote Link to post Share on other sites
SRdan Posted February 28, 2017 Share Posted February 28, 2017 There's a few ways to do it. I usedDet 3 ecuGlanza map sensorGlanza injectorsGlanza sumpCt9Glanza manifoldDecatAnd oil feed/return.Intercooler and exhaust also needed(Most of this I am selling in the for sale section) Quote Link to post Share on other sites
lukEp Posted February 28, 2017 Share Posted February 28, 2017 (edited) http://www.ukstarletowners.com/topic/105133-na-4efe-turbo-kit/#entry1207351 Edited February 28, 2017 by lukEp Quote Link to post Share on other sites
SRdan Posted February 28, 2017 Share Posted February 28, 2017 (edited) http://www.ukstarletowners.com/topic/105133-na-4efe-turbo-kit/#entry1207351Cheers Lukep Edited February 28, 2017 by SRdan Quote Link to post Share on other sites
Rich-k Posted March 1, 2017 Share Posted March 1, 2017 There's a few ways to do it. I usedDet 3 ecuGlanza map sensorGlanza injectorsGlanza sumpCt9Glanza manifoldDecatAnd oil feed/return.Intercooler and exhaust also needed(Most of this I am selling in the for sale section)Just this all bolted to the 4efe and aaay you go basically? Quote Link to post Share on other sites
SRdan Posted March 1, 2017 Share Posted March 1, 2017 Pretty much mate it's that easy.I'll message u back now Quote Link to post Share on other sites
