Phil Posted May 23, 2017 Share Posted May 23, 2017 On 5/21/2017 at 9:57 PM, MickL said: Hi PhilI've not seen limitations, I am running fuel lines internally in braided PTFE and put a non return on the breather pipe.Hope I'm not missing something, I will have to check the MSA book again.P.S I saw your old car the other week at Harewood, look well and was going well.If you don't have unto use the original tank I've pm'd you the few thoughts on the race fuel cell. Driiftie's offer maybe something to consider.Phil Quote Link to post Share on other sites
MickL Posted May 24, 2017 Author Share Posted May 24, 2017 Cheers Phil Quote Link to post Share on other sites
GordR Posted May 28, 2017 Share Posted May 28, 2017 (edited) Hey Mick! Great to see the progress. Was good to meet you at Harewood. Keep up the good work! If your ever short of parts I seem to have a workshop full of them I've collected over the years. Edited May 28, 2017 by GordR Quote Link to post Share on other sites
MickL Posted June 11, 2017 Author Share Posted June 11, 2017 (edited) Quick update Engine bay sprayed Edited June 11, 2017 by MickL Quote Link to post Share on other sites
MickL Posted June 11, 2017 Author Share Posted June 11, 2017 (edited) On 5/28/2017 at 4:40 PM, GordR said: Hey Mick! Great to see the progress. Was good to meet you at Harewood. Keep up the good work! If your ever short of parts I seem to have a workshop full of them I've collected over the years.Hey GordYou to mate, thanks buddy probably be in touch soonWhat time did you achieve that day?Mick Edited June 11, 2017 by MickL Quote Link to post Share on other sites
MickL Posted June 11, 2017 Author Share Posted June 11, 2017 (edited) Hey GordYou to mate, thanks buddy probably be in touch soonWhat time did you achieve that day?Mick Edited June 11, 2017 by MickL Quote Link to post Share on other sites
jay_glanza Posted June 20, 2017 Share Posted June 20, 2017 Reminds me of when I done mine there isn't many people who do it properly. Keep up the good work Quote Link to post Share on other sites
DRiiFTiE Posted June 20, 2017 Share Posted June 20, 2017 Looking well. Quote Link to post Share on other sites
MickL Posted June 21, 2017 Author Share Posted June 21, 2017 (edited) Took awhile but now install Seat rail supports Edited June 21, 2017 by MickL Quote Link to post Share on other sites
glanza ep91 23 Posted June 21, 2017 Share Posted June 21, 2017 what mm metal did u use to reinforce the firewall? Quote Link to post Share on other sites
MickL Posted June 22, 2017 Author Share Posted June 22, 2017 On 6/21/2017 at 6:40 PM, glanza ep91 23 said: what mm metal did u use to reinforce the firewall?I used 1.8mm for the firewall plate Quote Link to post Share on other sites
MickL Posted June 24, 2017 Author Share Posted June 24, 2017 Got the interior sprayed in satin black.Time for the roll cage to go back in. Quote Link to post Share on other sites
MickL Posted June 26, 2017 Author Share Posted June 26, 2017 (edited) Today I managed to get the afternoon off to install the cage in for last time for awhile I hope.Also fitted Seat rails and installed the Motordrive seat. Edited June 26, 2017 by MickL Quote Link to post Share on other sites
Ryncewind Posted June 26, 2017 Share Posted June 26, 2017 Coming along nicely mate! Quote Link to post Share on other sites
MickL Posted June 26, 2017 Author Share Posted June 26, 2017 On 6/26/2017 at 3:33 PM, Ryncewind said: Coming along nicely mate! Cheers buddy Quote Link to post Share on other sites
MickL Posted July 3, 2017 Author Share Posted July 3, 2017 (edited) Time for update on progress.Put a few things in the engine bay and started fitting the brake lines, I was going to use ABS deletion kit I got from TD and now decided to make my own using AN3 braided pipe and fittings. I did end up useing one of the pipes from the ABS deletion kit because I couldn't find AN fitting to come of the 2nd connection on brake master cylinder.I came of the 2nd fitting and routed through the bulk to a bias valve I fitted next to my hand brake and then on to a tee to feed the rear brakes. Edited July 3, 2017 by MickL Quote Link to post Share on other sites
MickL Posted July 3, 2017 Author Share Posted July 3, 2017 I have routed the brake line for the rear brakes through rear seat belt bolt hole in rear wheel arch. I had to grind down some of the bolt to allow the bulkhead fitting fit right.I made a bracket for the pipe to pass through to keep away from the wheel. Quote Link to post Share on other sites
Gainzy Posted July 3, 2017 Share Posted July 3, 2017 Skills! Looks great Quote Link to post Share on other sites
MickL Posted July 3, 2017 Author Share Posted July 3, 2017 On 7/3/2017 at 8:37 PM, Gainzy said: Skills! Looks greatCheers buddy Quote Link to post Share on other sites
Ollieh17 Posted July 4, 2017 Share Posted July 4, 2017 (edited) are you running braided line brake line from master cylinder all the way to calipers? I recently had to make up brake lines for my car and after research went with hard pipe over braided. Braided still has some degree of expansion, someone worked out it could cause as much as 2cm extra travel on the pedal. Might not sound a lot but would make it feel some what more spongy. Not sure if you use the car on the road either but im sure the use of those fittings is iffy come MOT Edited July 4, 2017 by Ollieh17 Quote Link to post Share on other sites
glanzadude Posted July 4, 2017 Share Posted July 4, 2017 Really nice build weldone Quote Link to post Share on other sites
MickL Posted July 4, 2017 Author Share Posted July 4, 2017 On 7/4/2017 at 8:20 AM, Ollieh17 said: are you running braided line brake line from master cylinder all the way to calipers? I recently had to make up brake lines for my car and after research went with hard pipe over braided. Braided still has some degree of expansion, someone worked out it could cause as much as 2cm extra travel on the pedal. Might not sound a lot but would make it feel some what more spongyYes I got braided all through the car, the inner pipe is PTFE is this same pipe your talking about?Comments welcomeMick On 7/4/2017 at 9:13 AM, glanzadude said: Really nice build weldoneCheers buddy Quote Link to post Share on other sites
Ollieh17 Posted July 4, 2017 Share Posted July 4, 2017 On 7/4/2017 at 2:34 PM, MickL said: Yes I got braided all through the car, the inner pipe is PTFE is this same pipe your talking about?Comments welcomeMickCheers buddyyeh mate, read a couple of different views but decided to stick with hardlines as hate a spongy pedal. Ideally for the best brake pedal you should use as much hard line as possible, only using flexi hose on the joints where it needs movements due to suspension travel Quote Link to post Share on other sites
MickL Posted July 4, 2017 Author Share Posted July 4, 2017 (edited) Cheers buddy Edited July 4, 2017 by MickL Quote Link to post Share on other sites
MickL Posted July 6, 2017 Author Share Posted July 6, 2017 (edited) Brakes are now done, so we were able carry out test on the bulkhead mode we did to and stop master brake cylinder moving. I can report no visible movement even with mate who is 6.2 pressing sudden hard stabs at the pedal.Also fitted is a sera master cylinder making pedal feel great.Just a note on Sera master cylinder, I had to adjust the rod in servo to make it shorter reach for pushing cylinder piston. Edited July 6, 2017 by MickL Quote Link to post Share on other sites
