Hello people
I'm in need of some help, managed to snap one of the front hub stud's after going a bit over the top with the breaker bar, I have a spare hub here which I have managed to bang one of the studs out of, can i re use it in my hub? and if so how will I get it in as it looks to me as if they are pressed in from the factory? Any help is greatly appreciated, starting a new job tomorrow so couldn't of came at a worse time.
Thanks
James
It should be splined, draw it into the hub using a wheel nut. You might need a spacer behind it ir use the alloy itself.
Easier with a battery gun. But can be done with a ratchet.
You'll be fine to run about with 3 wheel nuts in the mean time.
Cheers for replies lads, I managed to drag it in with a open ended nut as a spacer and the wheel nut using a ratchet, going to order all new studs though as it seems a bit crude to leave it like that.
Thanks again
James
  • 2 weeks later...
