Hi guys
Has anyone had issues when fitting a power flex anti lift kit combined with a 24mm anti roll bar. I have just fitted a black series kit and it's caused the bottom arm to touch my trd anti roll bar ?
Any thoughts
Yup. I took my whiteline arb off and put the stock back on as i didnt like the way it handled, i have seen people remove the plates under the ALK to solve it. That will remove some castor though.
Using the Whiteline ALK Mine has a fair bit of clearance on the passenger side and is about a 1mm from touching on the other side, this is with the supplied Whiteline drop links. Trying to work out why its offset :unknw:
Drivers side 1.48 degrees castor:
Passenger side 1.45 degrees castor:
Edited by StanMan
I dont think the whiteline bars are perfectly symmetrical. I had the same issue and it was catching in my exhaust tunnel so had to persuade the chassis to move a little bit.
Hmmmmm that had occurred to me. Checked mine last night and saw the same (slightly touching lip in exhaust tunnel) gonna get the grinder on it tonight and rust proof it after.
