Neil Posted April 8, 2008 Share Posted April 8, 2008 Started my car this morning about 6am (first really cold morning for a while) and the fan belt started squeeling its head off. Took about 10 mins to settle. Pretty sure my neighbours would have loved me for that Is there anything that can be done to stop this or is it a belt change job?CheersNeil Quote Link to post Share on other sites
Sparky Posted April 8, 2008 Share Posted April 8, 2008 Its not a fan belt mate Starlets dont have viscous fans It would be the alternator belt mate mine does the same when its damp and you first start it Really annoying, could get away with tightening it although if it has been doing it for ages (like mine) you may need a new belt Quote Link to post Share on other sites
StarletRick Posted April 8, 2008 Share Posted April 8, 2008 tighten it up a bit and itll stop.for a quick fix get a stick of chalk, when it squeels just dab the chalk on the belt and it will stop. Quote Link to post Share on other sites
Neil Posted April 8, 2008 Author Share Posted April 8, 2008 Cool cheers for that guys Lol @ fan belt, thats what working for BMW does to you I've got a new belt anyway just not had a chance to fit it yet. Are there any special tools required to fit or is it quite simple? Quote Link to post Share on other sites
nic1.3 Posted April 8, 2008 Share Posted April 8, 2008 StarletRick said: tighten it up a bit and itll stop.for a quick fix get a stick of chalk, when it squeels just dab the chalk on the belt and it will stop.sorry for the question but how does that stop it squeeling Quote Link to post Share on other sites
StarletRick Posted April 8, 2008 Share Posted April 8, 2008 same reason climbers use it. it LOVES the moisture and just soaks it all up. its alot faster than waiting for the car to warm up and letting it dry that way. Quote Link to post Share on other sites
Ryno Posted April 8, 2008 Share Posted April 8, 2008 if that fails then check your power steering belt, notorious to squeel like a pig on the 4E-FTE, espesh in a cold spell or wet weather! Quote Link to post Share on other sites
Lukey_B Posted April 8, 2008 Share Posted April 8, 2008 lol mines squeals and i have no power steering hahah! Quote Link to post Share on other sites
Tintin_SR Posted April 9, 2008 Share Posted April 9, 2008 yer myn is doing it the mow to, i put it down to oil cumin from the fucked rocker cover gasket, and the wee bits under the rocker cover bolts!! wear can i get thees from? Quote Link to post Share on other sites
Glanza_Ragger Posted April 15, 2008 Share Posted April 15, 2008 Mine squeels but i just claim its also got a supercharger fitted too... lololOne of the mechanics at my work, decided, hmm the belt squeels, lets spray some oil all over it..numpty.Had to replace the alternator 'because the whole thing was smotherd in oil As Rick said, chalk for a quick fix, just grind some up into powder and chuck over the belt and pulley..Or tighten it up, allthough its an ass to get to .Have fun Quote Link to post Share on other sites
Lukey_B Posted April 17, 2008 Share Posted April 17, 2008 any one got any pics on what exactly to tighten? Quote Link to post Share on other sites
briggers Posted April 28, 2008 Share Posted April 28, 2008 i tried the chalk otion lol held the chalk allong the belt it yanked it out my hand got stuck in the pulley and pulled the belt off lol . oops had to go to the garage in the end anyway Quote Link to post Share on other sites
scutch0 Posted June 15, 2008 Share Posted June 15, 2008 if your gonna change the alternator belt, change the pas one too... as you have to take it off to get to the alternator belt anyway.thats what i should have done! Quote Link to post Share on other sites
classickid21 Posted October 6, 2014 Share Posted October 6, 2014 (edited) Hi where abouts do tighten this up ?? alternator belt.. any online diagrams ? Edited October 6, 2014 by classickid21 Quote Link to post Share on other sites
akyakapotter Posted October 6, 2014 Share Posted October 6, 2014 Loosen top and bottom bolt piece of wood push towards firewall. hold wood in place while you tighten top bolt then bottom bolt job done. Quote Link to post Share on other sites
Manny Posted February 17, 2016 Share Posted February 17, 2016 Hi guys.My fan belt starts to squeel when I have the fan heater and lights on. I have changed the belt and had it tightened seems to have got a little worse now.Don't know what else it could be any ideas? Quote Link to post Share on other sites
Dale SR Posted February 18, 2016 Share Posted February 18, 2016 On 2/17/2016 at 11:19 PM, Manny said: Hi guys.My fan belt starts to squeel when I have the fan heater and lights on. I have changed the belt and had it tightened seems to have got a little worse now.Don't know what else it could be any ideas?it's your alternator belt that needs tightened Quote Link to post Share on other sites
StuDoc 72 Posted February 18, 2016 Share Posted February 18, 2016 If you have power steer and/or a/c then you have 2 aux belts if replacing one doesnt work then replace the other. Best way to tell which belt needs replaced is start the engine make the bitch squeel and then spray either belt with a small amount of WD40 whichever spray stops the squeeling then thats the offender. Quote Link to post Share on other sites
Manny Posted February 19, 2016 Share Posted February 19, 2016 Thanks guys will look into it. Quote Link to post Share on other sites
Manny Posted February 23, 2016 Share Posted February 23, 2016 Yeah it was the alternator belt was slightly loose. It's all good now. Thanks guys. Quote Link to post Share on other sites
