Batters Posted October 1, 2017 Posted October 1, 2017 Hi I know this has been done to death but I can't seem to find a definitive answer I have heard if you are doing a Celica twin pot brake upgrade fiat grande punto disks are a direct fit if they are from the 2007 to 2009 model which are these here https://www.eurocarparts.com/ecp/c/Fiat_Grande+Punto_1.4_2007/p/car-parts/regular-service/car-service-parts/brake-discs/?104580709&1&2044bfebdec21b7251f6706d0b53fbaadc761aca&000027Can anyone confirm this? Quote
Gainzy Posted October 1, 2017 Posted October 1, 2017 Only worth upgrading if you plan/running big power WMS or wilwoods are worth all day saving for Quote
Batters Posted October 1, 2017 Author Posted October 1, 2017 Yeah that would be ideal but I don't have that kind of money to spend Quote
Djaniero Posted October 5, 2017 Posted October 5, 2017 Sorry to thread jack. Would also like to know this too. I'm due discs and pads all around on my GT. Only plan on ever running 1bar max on td04 Quote
5e colin Posted October 6, 2017 Posted October 6, 2017 On 01/10/2017, 22:43:57, Batters said: Hi I know this has been done to death but I can't seem to find a definitive answer I have heard if you are doing a Celica twin pot brake upgrade fiat grande punto disks are a direct fit if they are from the 2007 to 2009 model which are these here https://www.eurocarparts.com/ecp/c/Fiat_Grande+Punto_1.4_2007/p/car-parts/regular-service/car-service-parts/brake-discs/?104580709&1&2044bfebdec21b7251f6706d0b53fbaadc761aca&000027 Can anyone confirm this? i know if you use the bzr twinpots then you use corsa disks strait fit no spacers or studa required i think the celica have same ofset sure some1 else will reply to comfirm Quote
goldenvtr Posted October 8, 2017 Posted October 8, 2017 wish id kept my mouth shut on youtube lol i let me secret out, been using these and laughing at the astra discs with "skimming" since around 2005 lol Quote
Batters Posted October 10, 2017 Author Posted October 10, 2017 On 10/8/2017, 11:39:59, goldenvtr said: wish id kept my mouth shut on youtube lol i let me secret out, been using these and laughing at the astra discs with "skimming" since around 2005 lol That's where I saw it so the fiat disks will work aswell On 10/6/2017, 6:24:02, 5e colin said: i know if you use the bzr twinpots then you use corsa disks strait fit no spacers or studa required i think the celica have same ofset sure some1 else will reply to comfirm Good to know I'll keep that I mind aswell Quote
lukEp Posted October 10, 2017 Posted October 10, 2017 I used a Vauxhall disc with twin pots and no skimming..... Just a spigot ring. Quote
Batters Posted October 10, 2017 Author Posted October 10, 2017 On 10/6/2017, 11:57:39, lukEp said: Corsa Gsi discs I believe. Was it these? All I'm after is when it's time to change my disks I don't want to have to machine them every time Quote
5e colin Posted October 10, 2017 Posted October 10, 2017 12 minutes ago, Batters said: Was it these? All I'm after is when it's time to change my disks I don't want to have to machine them every time corsa c gsi diks 260mm Quote
Batters Posted October 11, 2017 Author Posted October 11, 2017 15 hours ago, 5e colin said: corsa c gsi diks 260mm Thanks I'll have a look into it Quote
gorganl2000 Posted October 11, 2017 Posted October 11, 2017 18 hours ago, Batters said: Was it these? All I'm after is when it's time to change my disks I don't want to have to machine them every time how regular do you think you will be changing discs?....will this be strictly a track car? apart form that discs should last a very long time and 260 vs 277mm could be a notable difference ...even if they fit the same Quote
Batters Posted October 13, 2017 Author Posted October 13, 2017 On 10/11/2017, 4:24:13, gorganl2000 said: how regular do you think you will be changing discs?....will this be strictly a track car? apart form that discs should last a very long time and 260 vs 277mm could be a notable difference ...even if they fit the same Tbh it will probably be a long time before i need to change them I'm just lazy and wanted something to just bolt on with no machining Quote
