wakeabby14 Posted March 16, 2018 Share Posted March 16, 2018 Does the block need to be drilled to support them or do they fit in the existing head bolt holes. Cheers Quote Link to post Share on other sites
daniel_g Posted March 16, 2018 Share Posted March 16, 2018 The head bolts are straight fit. Its the head studs that require machine work. Quote Link to post Share on other sites
wakeabby14 Posted March 16, 2018 Author Share Posted March 16, 2018 On 3/16/2018 at 2:43 PM, daniel_g said: The head bolts are straight fit. Its the head studs that require machine work. Expand Is it better to go for studs or bolts? Is it correct when you use studs, you need to do machine work near the cams in the head so you can fit a socket bit in to tighten them up? Quote Link to post Share on other sites
maddox710 Posted March 16, 2018 Share Posted March 16, 2018 Waste of time and money with studs(unless using large garret running big big boost numbers) just get bolts Quote Link to post Share on other sites
wakeabby14 Posted March 16, 2018 Author Share Posted March 16, 2018 On 3/16/2018 at 6:50 PM, maddox710 said: Waste of time and money with studs(unless using large garret running big big boost numbers) just get bolts Expand sound nice one mate! Will do Quote Link to post Share on other sites
daniel_g Posted March 16, 2018 Share Posted March 16, 2018 Studs are better but you have to strip the block down, ie rods and pistons out the machine the block. The head needs work aswell. ARP bolts will be good enough for most builds. Quote Link to post Share on other sites
wakeabby14 Posted March 16, 2018 Author Share Posted March 16, 2018 On 3/16/2018 at 7:29 PM, daniel_g said: Studs are better but you have to strip the block down, ie rods and pistons out the machine the block. The head needs work aswell. ARP bolts will be good enough for most builds. Expand thanks mate appreciate it Quote Link to post Share on other sites
maddox710 Posted March 16, 2018 Share Posted March 16, 2018 On 3/16/2018 at 7:29 PM, daniel_g said: Studs are better but you have to strip the block down, ie rods and pistons out the machine the block. The head needs work aswell. ARP bolts will be good enough for most builds. Expand As Dan said a lot of work goes into putting studs in when most people just wanna max a td04 out Quote Link to post Share on other sites
gorganl2000 Posted March 17, 2018 Share Posted March 17, 2018 (edited) On 3/16/2018 at 8:27 PM, maddox710 said: As Dan said a lot of work goes into putting studs in when most people just wanna max a td04 out Expand so true.... Edited March 17, 2018 by gorganl2000 Quote Link to post Share on other sites
