aaddzz123 Posted June 21, 2018 Posted June 21, 2018 Does anyone else experience any fuel starvation when cornering a little hard? If my GT has 1/4 tank of fuel or less, it doesn't like to be thrown about. I went into a roundabout earlier today and had a little bit of lift off oversteer and lost all power, AFRs read off the scale lean so I know it's starvation. I just didn't expect it to starve at 1/4 tank lol. Does anyone else have this issue? Wondering if it could be due to something else or if I should consider fabricating a swirl pot. Quote
akyakapotter Posted June 21, 2018 Posted June 21, 2018 Can't say Ive ever had that issue with the glanza mabe the tank insides are different. No harm in whipping up a swirl pot though. Cheers nick. Quote
aaddzz123 Posted June 22, 2018 Author Posted June 22, 2018 Strange. I don't want to make a pot if it's just masking an issue that should be fixed. Guess I can start by taking the pump out and seeing if it sits right or whatever. Quote
SKINY Posted June 22, 2018 Posted June 22, 2018 Mine does it when nearly empty cornering hard, also Phil had bother with it in his last GT going through the chicane on the track too Quote
TrisK Posted June 23, 2018 Posted June 23, 2018 Have you got the little baggy on the end of the fuel pump? Might be worth checking it have fallen off Quote
morgey Posted June 23, 2018 Posted June 23, 2018 Have you got the little tub/baffle that sits around the fuel pump in the tank to stop the fuel running to the extremeties of the tank Quote
