jellybaby Posted August 29, 2019 Posted August 29, 2019 Anyone done it ? And is there a guide ? As I want to do mine and then tap holes and loctie bolts in to the cover to remove if needed Quote
H_D Posted August 30, 2019 Posted August 30, 2019 I drilled mines out and had AN fittings welded on from the inside then blob welded the baffle back in Quote
federalman Posted March 26, 2020 Posted March 26, 2020 (edited) Where are you located? I did mine on my s14; used stainless plate threaded in some small stainless bolts and then put a TIG tack on each to the plate to stop them coming undone. I didn’t trust thread lock. Edited March 26, 2020 by federalman Lockdown realisation 🤦♂️ Quote
federalman Posted March 29, 2020 Posted March 29, 2020 5 minutes ago, Sam44 said: Great idea this Seemed to be the easiest way, aluminium especially cam covers can be a nightmare to weld so using stainless removed that problem. Think I used 1mm stainless sheet and M3 dome head Allen key bolts they can’t rattle loose but you can drill the tops off and get a pair of grips to remove the thread from the cover Quote
