Sign in to follow this
burty
Wheel nuts
As all of you are aware my SR is having a major body works restoration Inc alloys, my wheels nuts are the original ones and will look nasty  any recommendations on a nice set for the speedlines not concerned about needing a locking one as it will live in the garage
Thanks
Share this post
Not sure what seat the speedlines have but I got a set of taper seat ones to suit my alloys from driftworks. Only a pound each!
https://www.driftworks.com/shallow-open-ended-wheel-nuts-m12-x-1-5-ford-toyota-etc.html
They are open ended rather than closed.
I would personally steer clear of aluminium wheel nuts. Not the correct material for the purpose. (IMHO).
Share this post
4 hours ago, burty said:
What's oem size lads?
The thread is M12 x 1.5mm.
Don't know the OEM hex size, I only bought the 17mm hex version because the hole in the alloy wheel face where the socket has to fit is very small and the larger hex meant a larger socket which wouldn't fit in deep enough to tighten the nut.
Share this post
Nuts4wheels website has all the flavours :) bought 2 sets myself over the years and they are great quality, go for Tuner nuts with the internal spline
Share this post
