burty Posted October 17, 2020 Posted October 17, 2020 As all of you are aware my SR is having a major body works restoration Inc alloys, my wheels nuts are the original ones and will look nasty any recommendations on a nice set for the speedlines not concerned about needing a locking one as it will live in the garage Thanks Quote
Claymore Posted October 17, 2020 Posted October 17, 2020 Not sure what seat the speedlines have but I got a set of taper seat ones to suit my alloys from driftworks. Only a pound each! https://www.driftworks.com/shallow-open-ended-wheel-nuts-m12-x-1-5-ford-toyota-etc.html They are open ended rather than closed. I would personally steer clear of aluminium wheel nuts. Not the correct material for the purpose. (IMHO). Quote
glanzadude Posted October 22, 2020 Posted October 22, 2020 I have the same nuts on my speedlines but they are 19s Quote
Claymore Posted October 23, 2020 Posted October 23, 2020 4 hours ago, burty said: What's oem size lads? The thread is M12 x 1.5mm. Don't know the OEM hex size, I only bought the 17mm hex version because the hole in the alloy wheel face where the socket has to fit is very small and the larger hex meant a larger socket which wouldn't fit in deep enough to tighten the nut. Quote
SKINY Posted October 23, 2020 Posted October 23, 2020 Nuts4wheels website has all the flavours bought 2 sets myself over the years and they are great quality, go for Tuner nuts with the internal spline Quote
burty Posted October 23, 2020 Author Posted October 23, 2020 Thanks for the info much appreciated Quote
