pocketrocket Posted February 13, 2006 Posted February 13, 2006 Right i have just Put Magnecor Leads on my Starlet GT and some times it feels like the car is miss firing but it aint?I am abit confussed can anyone shine some ligth for meThankyou Quote
BlackTarw Posted February 13, 2006 Posted February 13, 2006 they new or old leads?sounds like one might be dodgy.swap one of your new leads with one of your old leads, one at a time, do that that for each cylinder. Quote
BlackTarw Posted February 13, 2006 Posted February 13, 2006 also if it's a heavy missfire it could be that you're wired them up wrong. Quote
pocketrocket Posted February 13, 2006 Author Posted February 13, 2006 thanks for the idea but the leads are brand new though Quote
BlackTarw Posted February 13, 2006 Posted February 13, 2006 I wouldn't rule it out, I've been in that situation before with a new set of spark plugs when one was duff.plus it doesn't cost anything to try Quote
pocketrocket Posted February 13, 2006 Author Posted February 13, 2006 Im loving some bum fun at the moment Quote
Glanza_Ragger Posted February 13, 2006 Posted February 13, 2006 I wouldn't rule it out, I've been in that situation before with a new set of spark plugs when one was duff.plus it doesn't cost anything to tryAre you sure you have the leads on the right way as in fire'ing order?Make sure lead 1 goes to plug 1 etc Quote
pocketrocket Posted February 13, 2006 Author Posted February 13, 2006 yep i have had it all checked and everything is in order i hope it aint something bad Quote
Glanza_Ragger Posted February 13, 2006 Posted February 13, 2006 If it was fine before you fitted your new leads it has to either be a shot plug or firing order chap.Unless you got a dodgy lead in the pack? Quote
lobotomy Posted February 13, 2006 Posted February 13, 2006 What thickness are the leads? A mate put on some uprated ones which were too thick/thin (can't remeber rightly) and his misfired and held back until he eventually just got a new OEM set. Quote
BlackTarw Posted February 13, 2006 Posted February 13, 2006 Im loving some bum fun at the moment<{POST_SNAPBACK}> err, enjoy! Quote
Nanglebadger Posted February 13, 2006 Posted February 13, 2006 ^^Yeah i was wonderin about that too Phil. Quote
pocketrocket Posted February 13, 2006 Author Posted February 13, 2006 What thickness are the leads? A mate put on some uprated ones which were too thick/thin (can't remeber rightly) and his misfired and held back until he eventually just got a new OEM set.<{POST_SNAPBACK}>They are 8mm Magnecor it was doin it before i changed the leads and is doin it now but not all the time just now and again Quote
pocketrocket Posted February 17, 2006 Author Posted February 17, 2006 it is werrid cus i put new plugs in about a month ago Quote
