nic1.3 Posted July 2, 2008 Posted July 2, 2008 Rite Firstly thanx for looking at my thread any and all comments are welcome as well as any ideasok so onto the car96 4dr (Granny mobile)currently 131000 odd miles on itand now the spec Engine Rolla 4 branch manifold with custom paint jobTRD panel air filterDave Burwash lightweight crank pulleyDave Burwash lightweight powersteering pulleyExhaust wrapped manifold and downpipe to catMagnecor 8.5mm leadsNGK iridium plugsSard magnetic oil filterMagnetic sump boltCustom earthing wiring kitTRD 4efte uprated engine mounts (modded to suit)Custom made N/A cooling panel TransmissionCustom made quick shift gear leverCustom made solid steel gear shift bushingsRoller bearing gear linkage bearingssolid steel gear shift bushings Chassis Koni adjustable dampersTein springsUltra Racing 4 point lower arm BarWhiteline Anti lift KitWhiteline rear adjustable anti roll barRSR ajustable panhard rod Rolling Stock15" x 7.5 Technomagnesio rally spec rims in gold finish 195 x 50 x R15 Pirelli P5000 Drago tiresRed anodised anti theft valve caps Exterior6000K HID lightsFiat Punto rear wiperClear front indicator lensesClear side indicators with chrome bulbsColour coded Toyota front badgeDebadged rear InteriorGlanza optional armrestMomo pedalsPolished Gear stickVibe remote bass adjustments dial4 door central locking kit off ebay(it really does work without problems) ICESony CDX M8800 head unitStringer Zero gauge wiring kitJL Audio E4300 4 channel amp componentsVibe slick A7 digital mono-block amp to subVibe remote bass adjustments dial10" sub in 6th order band pass enclosureFusion power plant 130mm components Security AH���.now that I will keep to myself�� Stuft to fitCorbeau FIA approved bucket seats in greyglanza elec mirrorsPlans for the futureshort term plansTRD engine mounts to fit as my own are knackered DONEfind a suitably unusual splitter and mod to fitFit custom made solid steel gear shift bushings DONEMedium term plansnew cambelt new TRD 0.5mm head gasketGT Turbo or V back axle conversion for the discs3G rear groved discssteel braided brake linesadj. panhard rod NONEanti lift kit NONErear anti roll bar NONETRD bushings all roundpaint and fit glanza top spoilerVolk Rays red lug nutsLong Term plansfull glanza front end + sideskirts + rear full respray5E rebuilt to serious specBZR levin big disc conversionPictures will be posted soon......real soonoh and here they are Quote
Jozinobi Posted July 2, 2008 Posted July 2, 2008 Glad to see you have finally taken the plunge Nic.Nice wee spec you have there too with some choice parts not usually seen much on N/As.Red EPs are for winners by the way How do you find the difference from the lightweight pulleys and have you come across any problems with them?Will be good to see some pictures of them.Also pm sent mate.Talk soonJoz Quote
nic1.3 Posted July 2, 2008 Author Posted July 2, 2008 thanx mate my goal is to make a serious starlet from the most unlikely model.... nuthing but the best for my motor.for now she will remain a bit of a sleeper without 2much body work.yeah the lightweight pulleys do make a difference it really does rev alot more freely with them and she pulls a tiny bit harder aswell id say, there is no issues with the pulleys that i have fitted, but the water pump is the press fitted version on mine and i bought the bolt on one and alternater pulley are is a different shaft size on my own alternatorpm replied to Nic Quote
Rich Posted July 3, 2008 Posted July 3, 2008 Nice spec and some decent plans you have there. Wish I could follow a plan like that Get some pics up they say a thousand words ;) Quote
SiCaln Posted July 3, 2008 Posted July 3, 2008 glad you took the plunge mannice spec already, sounds like this is gonna be one of th ose threads to watchall the best of luck with it mate Quote
Liam_D Posted July 3, 2008 Posted July 3, 2008 Like the others have said, it sounds awesome. Get some pics up though dude. Quote
nic1.3 Posted July 3, 2008 Author Posted July 3, 2008 thanx lads im going to clean nd polish it up 2morow and take sum nice photos as i want sum new ones. Quote
nic1.3 Posted July 7, 2008 Author Posted July 7, 2008 Alrite peeps photos added to the first post Quote
nic1.3 Posted July 9, 2008 Author Posted July 9, 2008 alrite guysI fitted the TRD engine mounts yesterday..what a difference they've made.there was some modifying needed to be done to make the rear lower mount work (exhaust mounting brackets)but i will let the photos do the talking, so here there are.all the mountsPart no. for the lower rear mountPicture guide to modifications done to rear mountNic Quote
Liam_D Posted July 9, 2008 Posted July 9, 2008 Looking good mate, Have you noticed much different from the uprated Pulleys?? Quote
nic1.3 Posted July 9, 2008 Author Posted July 9, 2008 Looking good mate, Have you noticed much different from the uprated Pulleys??thanx ladyeah the lightweight pulleys do make a difference it really does rev alot more freely with them and she pulls a tiny bit harder aswell id say,also when cruising my mpg is fairly good i can get up to 40-42 mpg, so i recon that they help that sum bit also Quote
Sparky Posted July 13, 2008 Posted July 13, 2008 Very nice motor mate like the seats are they in yet? ;) Quote
nic1.3 Posted July 14, 2008 Author Posted July 14, 2008 Very nice motor mate like the seats are they in yet? ;)thanx man. they are a sweet shade of grey in personno the seats arent in yet, ive owned them for a year almost now and they've been in and out, im having to do custom brackets for them as im not quiet happy with the height of them when theyre in( theyre a little too high),also my girlfriend has problems fitting into them and im sick of her going on bout em so im not the fastest bout refiting them,i kno thats a weak excuse but they'll be in the car eventually...... Quote
nic1.3 Posted July 16, 2008 Author Posted July 16, 2008 alrite guys Ive fitted my custom shaved and painted rocker coverwhat do ye think??? Quote
SiCaln Posted July 16, 2008 Posted July 16, 2008 that looks so clean, awesome work mate i must say Quote
JAG Posted July 16, 2008 Posted July 16, 2008 That looks fresh!So nice n shiney Like the black toyota on there to looks gangsta matey Quote
nic1.3 Posted September 4, 2008 Author Posted September 4, 2008 That looks fresh!So nice n shiney Like the black toyota on there to looks gangsta matey Thanx jag, its taken alot of polishing to get toyota's 3E5 red shiney, Im finding it easy to keep the shine nowadays though with the help of AutoGlym's Aqua Wax....tastey stuff.I decided to do the toyota black in order to keep things different, the whole polished bare metal Toyota is too common for my liking, but I do think that it is still nice. Quote
nic1.3 Posted September 4, 2008 Author Posted September 4, 2008 Well its been a while since I updated the tread, mainly due to the fact that I havnt done much to it lately.Here's what I've;Crystal headlightsI painted the backs of the lamps matt black to add a little more detail to them. it turned out sweet and I will post up pic's of it soon.For now here's sum photos of the change over.You can clearly see the difference in the old and crystall headlights now, Also the crystall headlights seem to make the HID's work better, as in that the light is now projected much more evenly. One more for ya.Soild Steel Shifter BushingsJust made these out of some 16mm diameter x1mm thick steel tube.Results...The gear change is more precise and feel abit sweeter, so for 4.50 euro how far wrong can you goThats all for nowNic Quote
SiCaln Posted September 5, 2008 Posted September 5, 2008 really love the clear headlights, wish they made em for the V like thatwhy did u mod that TRD mount was it to support exhuast? Quote
nic1.3 Posted September 5, 2008 Author Posted September 5, 2008 really love the clear headlights, wish they made em for the V like thatwhy did u mod that TRD mount was it to support exhuast?Yeah Basically, I had to weld on the hangers for exhaust on to the lower engine because that is where the exhaust is supported on the N/A, After that its a straight run support wise to the backbox.I guess that the turbo exhaust is supported in other locations. Quote
SiCaln Posted September 5, 2008 Posted September 5, 2008 ah i see yea theyr further down the pipe Quote
Asad Posted September 7, 2008 Posted September 7, 2008 woooooooo hoooooo another 4dr........fought i was the only one!its given me insparation to clean the engine bay up properly and post up pics/mods! Quote
nic1.3 Posted September 7, 2008 Author Posted September 7, 2008 woooooooo hoooooo another 4dr........fought i was the only one!its given me insparation to clean the engine bay up properly and post up pics/mods!Hey man. thanxI dont think that there are many 4Drs alrite on here alrite.With a little work in the engine bay they can look sweet. Quote
Gavin Posted September 23, 2008 Posted September 23, 2008 Nice one man!That is one clean engine bay!Im up in dublin myself. Quote
